Driver window won't stay glued - Ford Truck Enthusiasts Forums
Old 06-20-2010, 08:31 PM
eaglestone eaglestone is offline
eaglestone is starting off with a positive reputation.
We have a 2000 Explorer and the driver window popped out of the track last year. I glued it back and it lasted about 6 months. After gluing it now, we're lucky to get a few weeks before it pops again. I've used both Epoxy and a windshield specific adhesive, both neither lasted.
Looking at replacement window regulators, they don't look like mine. Some even have configurations for bolts that go through the window.
I guess my question is this: is this an indication of worn regulators? Is there something else that could cause this problem?
Thanks...
Old 06-20-2010, 10:03 PM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
You need to figure out what is binding. Even though it's difficult to get glue to stick to glass, the window should move pretty freely within the weatherstripping and seals. Maybe some cola was spilled along the door panel or the window is not aligned properly, causing excessive drag. When the adhesive releases the glass, can you move the window glass around pretty freely? I'd expect that if you were to let go of the glass it would want to drop inside the door. If it wants to stay put, there is something causing the glass to drag. I'd be focusing on making sure the window is located properly within the weather stripping and that the weather stripping is clean and not sticky. The window regulator won't be the source of the issue, unless it's alignment of the regulator.
-Rod
Looking for vrv for 1988 F350 vacuum regulator valve swhitney133 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 22 11-07-2016 03:40 PM
gluing window felt, help! sdetweil 1948 - 1956 F1, F100 & Larger F-Series Trucks 41 03-05-2010 07:53 PM
rear driver side power window motor replacement bigacre Explorer, Sport Trac, Mountaineer & Aviator 8 08-26-2009 01:35 PM
1969 torino window off track pashtrd General Automotive Discussion 3 10-11-2006 07:44 PM
Door Handle Problem. 97expy 1997-2006 Expedition & Navigator 1 01-30-2004 06:24 PM
Tags
automatic, back, driver, drivers, expedition, explorer, ford, glue, glueing, regulator, replacement, stay, stripping, track, truck, weather, window, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
