93 f150 clutch - Ford Truck Enthusiasts Forums
93 f150 clutch
Old 06-20-2010, 08:15 PM
rmalottwtes30's Avatar
rmalottwtes30 rmalottwtes30 is offline
rmalottwtes30 is gaining momentum as a positive member of FTE.
93 f150 clutch
helped a buddy replace the clutch in his 93 f150 4 speed transmission with a 4.9. The retaining clip that holds the slave cylinder broke, what is the part number for this? Also we rigged it up until we can get the part, the slave cylinder moves a little would it cause it to shift hard? We can put it in first and will grind, it will do it to any gear but if you put it into 2nd gear first then it will go into any gear.
Part number for the retaining clip is?
also how do you bleed this thing, it does not have a bleeder on the slave cylinder?
Thanks guys!
Old 06-26-2010, 07:57 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
I'm not sure about a part number, but I think to bleed the slave requires manually moving the slave cylinder held vertically with the hose end up to push the air up to the master cylinder. If the slave is moving at all in its mount, it could definitely keep the clutch from releasing fully (as would air in the system) which would cause difficulty getting it to go into gear.
trouble bleeding the clutch? |WYG|SS 1987 - 1996 F150 & Larger F-Series Trucks 10 11-16-2015 07:54 PM
Clutch Kit Question 93tankus 1987 - 1996 F150 & Larger F-Series Trucks 1 11-02-2007 09:16 AM
Trying to find a slave cylinder retainer clip hoxiii 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 06-13-2007 05:35 PM
slave cylinder retaining clip? Richard Forster Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 10-31-2006 12:35 AM
91 F-250 Clutch BernDog 1987 - 1996 F150 & Larger F-Series Trucks 3 05-30-2006 08:29 AM
Tags
150, 87, 93, clip, clutch, cylinder, cylinders, f150, f15o, ford, installation, pin, retainer, retaining, slave, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
