Where does this vacuum line goto?
Excuss my dumb circles lol.
Starts here at brake booster.
Then goes from the brake booster to this.
From there it leads to this random vaccuum line with no home.
Theres also those other two shown beside it. I hate all these lines everywhere and I cannot read the vacuum line sheet at all.
Thanks guys.
Thanks guys.
Do your power brakes work? That large line from the booster usually goes straight over behind the aircleaner and hooks to a large fitting on the intake behind or underneath the carb.
What carb do you have on this engine? Is it original? Pull the aircleaner off and take a picture of the whole top of the engine.
JGreen,I feel your pain.
All those hoses for a 1 barrel and a 6.
Removing the smog stuff *****-nilly is generally not the way to go unless you first investigate
what the device is, what it does and when, and what adjustments might need to be made as
a consequence. Everything has a purpose and it all works together and some of it isn't even
related to smog controls but, rather, is part of general engine operation.
If and when I get a chance today or tomorrow, I will take a picture of my setup for you. I do have several picture of it here, but none of the other end. My 1985 Ford F150 4x2 pictures by Grubbworm_photos - Photobucket
That hose provides manifold vaccum to your brake booster to power it. It needs to be hooked up to a big manifold vacuum source seperate from the PCV. Usually in a vaccum tree in the back of the manifold or a big port in the back of the carb.
And wow you should do something about that mess of vacuum lines, I'm sure there only causeing trouble for you. You really only need like 5 of them to make the truck run right, the rest can be removed along with the AIR pump. Unless you still have a cat then it's more complicated.
Thanks for all the responses guys! I'll take a picture with the air filter off today. And Yea i'd love to get rid of the mess of lines that are swallowing the engine...its sorta a joke and I can blame my father and his friends on all that ha!
Ford shes looking great bro! Thats where I want to be with mine hehe. Btw looks like u need a K&N air filter, why not use the money you made and buy one! =P
That vacuum line "with no home" may go to the vacuum resorvoir, or "coffee can."
On my 1985 carbureted 302, the brake booster line connects to the large vacuum tree like yours does (but located on the back of the intake on my V8). From this vacuum tree, my truck has a hose similar size to yours that goes over to the black "coffee can", located on the passenger's side inner fender.
And/or, it may connect to yet another tree with three ports that is attached up at the top of the firewall, (shown in FordNFishinLover's engine pic) on the passenger's side.
Mine has a vacuum hose running to both the coffee can and the firewall-mounted vacuum tree. Check both places and see if yours has a vacuum hose there.
Ford shes looking great bro! Thats where I want to be with mine hehe. Btw looks like u need a K&N air filter, why not use the money you made and buy one! =P[/quote]
Haha thanks, yeah haha that moneys going toward the 20 other different things i actually need for my truck! haha. Plus for 25 bucks this filter looks great and brings in alot of air. Can hear the thing breathing when you drive if you listen closely.
Does anyone know of a guide to safely remove all the unnecessary lines to clean it up? I've removed the ac and smog pump and would love to get rid of all the junk everywhere.
