Where does this vacuum line goto?
Old 06-20-2010, 06:35 PM
JGreen236's Avatar
JGreen236
JGreen236 is offline
Excuss my dumb circles lol.
Starts here at brake booster.
Then goes from the brake booster to this.
From there it leads to this random vaccuum line with no home.
Theres also those other two shown beside it. I hate all these lines everywhere and I cannot read the vacuum line sheet at all.
Thanks guys.
Old 06-20-2010, 09:03 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
Do your power brakes work? That large line from the booster usually goes straight over behind the aircleaner and hooks to a large fitting on the intake behind or underneath the carb.
What carb do you have on this engine? Is it original? Pull the aircleaner off and take a picture of the whole top of the engine.
Old 06-20-2010, 09:22 PM
FordNFishinLover's Avatar
FordNFishinLover
FordNFishinLover is offline
If you dont have emissions testing there i suggest you remove all your smog crap. If you do that you wont have all the stupid wires/tubes hangin around.
Heres a picture of my truck without the emissions on.
Sorry kind of a bad picture.
Old 06-20-2010, 09:38 PM
Fordzilla80's Avatar
Fordzilla80
Fordzilla80 is offline
That sounds easy,but when you have about 40 hoses,it gets a little hard to decipher what is needed and what isn't.It makes it harder when you have the Cali emissions package.
JGreen,I feel your pain.
All those hoses for a 1 barrel and a 6.
Old 06-20-2010, 11:15 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Removing the smog stuff *****-nilly is generally not the way to go unless you first investigate
what the device is, what it does and when, and what adjustments might need to be made as
a consequence. Everything has a purpose and it all works together and some of it isn't even
related to smog controls but, rather, is part of general engine operation.
Old 06-21-2010, 05:45 AM
Sport45's Avatar
Sport45
Sport45 is offline
It's just a WAG, but I'm guessing the one you're holding used to go to the hot air diverter on the original breather snorkel. The other two may have been connected to each other. Do any of them draw air at idle?
Old 06-21-2010, 07:33 AM
Grubbworm's Avatar
Grubbworm
Grubbworm is offline
If and when I get a chance today or tomorrow, I will take a picture of my setup for you. I do have several picture of it here, but none of the other end. My 1985 Ford F150 4x2 pictures by Grubbworm_photos - Photobucket
Old 06-21-2010, 07:35 AM
Grubbworm's Avatar
Grubbworm
Old 06-21-2010, 07:57 AM
Opossum's Avatar
Opossum
Opossum is offline
X2
That hose provides manifold vaccum to your brake booster to power it. It needs to be hooked up to a big manifold vacuum source seperate from the PCV. Usually in a vaccum tree in the back of the manifold or a big port in the back of the carb.
And wow you should do something about that mess of vacuum lines, I'm sure there only causeing trouble for you. You really only need like 5 of them to make the truck run right, the rest can be removed along with the AIR pump. Unless you still have a cat then it's more complicated.
Old 06-21-2010, 09:54 AM
JGreen236's Avatar
JGreen236
Thanks for all the responses guys! I'll take a picture with the air filter off today. And Yea i'd love to get rid of the mess of lines that are swallowing the engine...its sorta a joke and I can blame my father and his friends on all that ha!
Ford shes looking great bro! Thats where I want to be with mine hehe. Btw looks like u need a K&N air filter, why not use the money you made and buy one! =P
Old 06-21-2010, 11:02 AM
LARIAT 85's Avatar
LARIAT 85
LARIAT 85 is offline
That vacuum line "with no home" may go to the vacuum resorvoir, or "coffee can."
On my 1985 carbureted 302, the brake booster line connects to the large vacuum tree like yours does (but located on the back of the intake on my V8). From this vacuum tree, my truck has a hose similar size to yours that goes over to the black "coffee can", located on the passenger's side inner fender.
And/or, it may connect to yet another tree with three ports that is attached up at the top of the firewall, (shown in FordNFishinLover's engine pic) on the passenger's side.
Mine has a vacuum hose running to both the coffee can and the firewall-mounted vacuum tree. Check both places and see if yours has a vacuum hose there.
Old 06-21-2010, 10:39 PM
FordNFishinLover
Ford shes looking great bro! Thats where I want to be with mine hehe. Btw looks like u need a K&N air filter, why not use the money you made and buy one! =P[/quote]
Haha thanks, yeah haha that moneys going toward the 20 other different things i actually need for my truck! haha. Plus for 25 bucks this filter looks great and brings in alot of air. Can hear the thing breathing when you drive if you listen closely.
Old 06-24-2010, 07:47 PM
JGreen236's Avatar
JGreen236
Alright checked and the firewall tree is all filled with vacuum hoses already. Along with the black "coffee can". Behind the carb and infront of the firewall seems to be some sort of aluminum vacuum booster of some sort, its connected to the manifold I believe and seemed to have an open spot for a vacuum line. I ment to get some pictures but it got dark to easy, managed to snag a pic of the vacuum line sticker if that helps any.
Does anyone know of a guide to safely remove all the unnecessary lines to clean it up? I've removed the ac and smog pump and would love to get rid of all the junk everywhere.
Old 06-24-2010, 10:21 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
EGR valve?
Does it look like this:
Old 06-24-2010, 10:22 PM
JGreen236's Avatar
JGreen236
Yes thats exactly what it is. Is there a nipple off on the side of it to where a vacuum hose should be?
Quick Reply: Where does this vacuum line goto?
