Engine backfires through carb and wont start - Ford Truck Enthusiasts Forums
Old 06-20-2010, 02:51 PM
Truckmano5's Avatar
Truckmano5 Truckmano5 is offline
Truckmano5 is starting off with a positive reputation.
I have just reinstalled my distributor after some engine work. All the engine will do when i try to crank it is pop and huff through the carb. Is the dizzy 180 degrees off? I have the engine at what I believe is TDC.
Old 06-20-2010, 03:58 PM
4x4 Bart 4x4 Bart is offline
4x4 Bart is gaining momentum as a positive member of FTE.
I would try moving the distributor 180. Make sure at TDC the rotor is pointing to #1
Old 06-20-2010, 07:19 PM
four.six four.six is offline
four.six is starting off with a positive reputation.
Yep sounds like your 180 out. It's trying to fire on the intake stroke.
Old 06-20-2010, 11:06 PM
Truckmano5's Avatar
Problem solved. One hundred and eighty degrees around and down the road I went. Thanks a ton fellas.
Carb tuning problems tank_153 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 12-22-2015 11:06 AM
85 F150 4.9 Fires but wont idle or stay running Jagesage 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 08-13-2015 02:59 PM
Blow through turbo set up with propane???? pud Alternative Fuels, Hybrids & Mileage 1 07-10-2006 03:17 PM
carb. blow through vs draw through serving_time Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 5 02-09-2005 02:51 AM
Backfiring through the carb 51dueller Fuel Injection, Carburetion & Fuel System 8 10-09-2004 12:29 PM
Tags
78, back, backfires, backfiring, carb, carburetor, crank, doesnt, engine, fires, motor, small, start, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
