How to replace Door glass in 1952 F-1 - Ford Truck Enthusiasts Forums
Old 06-20-2010, 11:37 AM
mathew21's Avatar
mathew21 mathew21 is offline
mathew21 is starting off with a positive reputation.
Can someone help this newbie out. I need to replace the passanger side door glass (roll up window) in a 1952 F-1. I'm not sure how the glass comes out of the track.
Thank you, Matt
Old 06-20-2010, 01:39 PM
firstrider's Avatar
firstrider firstrider is offline
firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.
It comes out thru the door access panel hole .Roll the window down .Remove the 2 clips that hold it to the bottom window channel .Roll the window regulator up a little . Window will drop down .Tilt and remove .
Old 06-20-2010, 09:26 PM
mathew21's Avatar
Thank you. I will try to do it tomorrow.
Old 06-23-2010, 11:39 AM
ZOOT's Avatar
ZOOT ZOOT is offline
ZOOT has a good reputation on FTE.ZOOT has a good reputation on FTE.
52 DRIVER SIDE WINDOW
Hi, I new to this forum. Have a 52 f1. Once you remove the window from the door, the glass itself is attach to a steel U shaped mount. Removing this is tricky so if you don't need to replace the glass, leave it be. If you do, use a rubber hammer gently, no screwdrivers or the glass will break. Also there is webbing in between the glass and the steel mount which will have to be replaced to seat the glass to avoid chipping and excess vibration. Hope that helps.
Old 06-23-2010, 02:40 PM
firstrider's Avatar
To remove bottom glass channel on door glass introduce the channel to a heat gun . This will loosen up the welded on glass setting tape from 60 yrs. ago .This worked for me .Later , Denny
Old 06-24-2010, 05:37 PM
mathew21's Avatar
Thanks for the tips. I just came back to this post to report I was able to get the Window out but I was not sure on how to get the glass out of the channel.
Thanks, Matt
Old 06-25-2010, 12:37 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Quote:
Thanks, Matt
Look at the post above yours.
Old 03-18-2016, 12:06 PM
william11 william11 is offline
william11 is starting off with a positive reputation.
windows wont roll up or down, what is the issue? like what aprts to i need to buy or replace etc. also the door handles dont work. driver side works from the outside but not inside(doesnt matter placement of handle inside). Pass works the same but you have to have the handle in the right place on the inside(will not open from inside).so same question what do i need to buy or replace ti fix?
51 window glass replacement v860rich 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 10-06-2016 05:31 PM
1952 glass lift channel offset help Tilleyman 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 10-19-2015 06:46 PM
Question re: installing glass in vent windows 1952 F-1 dagwood387 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 07-01-2015 09:23 AM
Door window and vent window removal DougofMontana 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 06-22-2015 11:30 PM
Single Door Glass for 1948-52 F1 AmeriKen 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 03-21-2015 12:27 PM
Tags
1951, 1952, channels, door, f1, ford, glass, installation, regulator, removal, repair, replace, truck, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
