ground strap question - Ford Truck Enthusiasts Forums
Old 06-19-2010, 10:54 PM
66ca's Avatar
66ca 66ca is offline
66ca is starting off with a positive reputation.
i have a 97 F350 and there is a ground strap on the passenger side firewall that is screwed to the firewall, but the other end is unattached. Where does it go? Im thinking the motor, but not for sure.
Old 06-19-2010, 11:13 PM
nighthawk285's Avatar
nighthawk285 nighthawk285 is offline
nighthawk285 has a very good reputation on FTE.nighthawk285 has a very good reputation on FTE.nighthawk285 has a very good reputation on FTE.
gotta picture? I think it might be the one that bolts to the hood
Old 06-19-2010, 11:33 PM
66ca's Avatar
i cant post pics because of my post count....but you think it goes from the firewall to the hood?
Old 06-19-2010, 11:46 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm Ohio Ford Farm is offline
Ohio Ford Farm is gaining momentum as a positive member of FTE.Ohio Ford Farm is gaining momentum as a positive member of FTE.
IS it LONG or Short? I have two ... well one and part of one LOL I have a long one that goes to the motor and the other yes went to the hood.
<a href="http://s601.photobucket.com/albums/tt93/Ohio_ford_farm/?action=view&current=000_0338.jpg" target="_blank"><img src="http://i601.photobucket.com/albums/tt93/Ohio_ford_farm/000_0338.jpg" border="0" alt="ground cables"></a>
Old 06-20-2010, 12:03 AM
to post pics, upload them to photobucket then just use the IMG code
So there's two for you, which one?
Old 06-20-2010, 12:05 AM
66ca's Avatar
well, mine is right there like that, but only has one....and its long enough to reach the intake, so i guess it goes to the motor somewhere?
Old 06-20-2010, 12:06 AM
66ca's Avatar
excuse me for sounding stupid, but why in the world would the hood be grounded?
Old 06-20-2010, 12:08 AM
Quote:
If its that long it goes to the EGR valve. One of the bolts " should" be one of the great PIA bolt with a stud on top type of thing. and the ground wire goes on there.
Hood was grounded due to some of the under the hood lights needed body ground to work and a ground jumper works better then a grease filled hood hinge.
Old 06-20-2010, 12:10 AM
66ca's Avatar
ok. So where can i find this EGR valve? lol
Old 06-20-2010, 12:14 AM
<a href="http://s601.photobucket.com/albums/tt93/Ohio_ford_farm/?action=view&current=000_0339.jpg" target="_blank"><img src="http://i601.photobucket.com/albums/tt93/Ohio_ford_farm/000_0339.jpg" border="0" alt="egr"></a>
Old 06-20-2010, 08:36 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
That would work but it's not the factory location, this wire should go to the rear most passenger side stud on the back of the lower intake.
Quote:
Originally Posted by Ohio Ford Farm View Post
Old 06-20-2010, 10:11 AM
66ca's Avatar
hmmmmm....i dont think mine looks anything like that
Old 06-20-2010, 10:15 AM
Opossum Opossum is offline
Opossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to all
You really can't have too many ground straps and it doesn't really matter where it's hooked up on the motor.
Old 06-20-2010, 07:27 PM
66ca's Avatar
well i saw a stud near the middle of the intake with nothing on it, i guess it can go there?
Ground Strap NS70250 1967 - 1972 F-100 & Larger F-Series Trucks 2 08-16-2016 12:45 PM
GROUND STRAP HOT FRANKLIN0716 Excursion - King of SUVs 10 01-15-2016 12:43 PM
Ground strap sgauvry 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 09-22-2015 02:46 PM
Hood ground loop question Millam 1967 - 1972 F-100 & Larger F-Series Trucks 5 08-05-2015 12:05 AM
1949 F1 Grounding Dick Kranz 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 01-25-2015 03:41 PM
Tags
1988, 2002, 4vho, engine, escape, f150, fire, ford, ground, passenger, side, strap, straps, truck, wall
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
