Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Towing and Hauling Guides
- How to Measure Trailer Tire Pressure
Step by step instructions for do-it-yourself repairs
Towing Tire Pressure
Hey Guys,
Looking for advice from the folks who tow with there expy. Getting ready for our fist summer tow and it's quite further than before. I'm trying to to find out what pressure we should have in our rear tires, or front if they should change during towing. Book and door sticker only have the driving pressure (35) but nothing for towing. We have the 20' pirellis. Will be towing a 30' travel trailer with about 650 lbs tongue if that matters.
The pressure on the door sticker will handle the Gross Axle Rating. More pressure won't increase the axle capacity.
I run 700+ pounds of tongue weight via an Equal-i-zer weight distribution hitch and find an extra 5 psi on the rear tires takes some of the squirm out of the rear P-rated radial tires on the Expedition.
Make sure your trailer tires are maximum sidewall pressure and your front suspension is lower with the trailer hooked up than not. Otherwise your WDH ain't working.
We're about 25' ball to spare tire.
-- Chuck
-- Chuck
Thanks Chuck. I was thinking about bringing the PSI up to 40, more for the squire as you put it. What do you mean about "trailer tires are maximum sidewall pressure"? I'm assuming the max tire pressure? If so then yes that's what we've got running in the trailer tires as listed on the tire wall. Also when you hook up the WDH have you measured the distance your front end gets down? I've tried a few different settings and can't get much difference on actual height measurement on the front. But think I've found the sweat spot between front and rear end displacement.
Are you running with any anti sway devices? I'm just running WDH but haven’t had too many issues with sway yet and wonder what your experience is?
I'm running an Equal-i-zer WDH which has built in sway control. About $460 (delivered) from RVWholesalers.
I don't recall how much front suspension loading I have, but it's important to have some, otherwise no weight is coming off the rear axle. Trailer tows pretty level, as it should. There's a lot of slop in the Expedition receiver so it took a more severe setting than I originally thought.
The purpose of the WDH is not to level the tow vehicle but to transfer weight. Guys with real stiff rear suspensions who skip a WDH often wonder why their steering is so light.
-- Chuck
-- Chuck
I pump up my Expy tires to 40 lbs when towing and run my trailer tires at 65 lbs, the maximum inflated pressure. I'm towing 33ft. and have the Equalizer hitch like Chuck, no problems to date, I had a bit more sway then my 06 F-150 I use to tow with but I replaced the rear sway bar with a larger Helwig sway bar and now it feels more secure.
Havnt towed TT's in a while, just 8K worth of boat with a WD hitch. I used air lift bags on the rear to level the rear for short trips.
My experience is that you can feel when the weight is properly on the front end.
When the TT his hooked up, it should be level, F to R and the tow vehicle should drop approximately the same F to R, with the bars hooked up. Some people dont understand that the ball height on the hitch must be adjusted for each setup.
You can make minor changes by just adding or dropping one link on the WD chains. On the interstate, it helps with control when big rigs pass you at 70 and try to blow you off the road. In that case, I liked to xfer slightly more weight to the front for better stability. On slower switch backs, a little weight off the front helped with steering ease and lightened things up.
My .02---
My .02---
Tnriverside
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
29
03-22-2016 02:20 PM
state
08-27-2003 10:57 AM
