How to: Fuel filter and oil filter change in a 6.0L/6.4L - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-17-2014, 06:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
Old 06-19-2010, 02:29 AM
TennesseeMustangPerf's Avatar
TennesseeMustangPerf TennesseeMustangPerf is offline
TennesseeMustangPerf has a good reputation on FTE.TennesseeMustangPerf has a good reputation on FTE.
At the request of a fellow member here, I have decided to do a how to on changing th fuel filters on a 6.0L and 6.4L PSD truck. I have decided to do this writeup on a 2003 6.0L Powerstroke F-350 dually, mainly because that's the truck I've got. The process should be the same for the 6.4L as well as all 250, 350, 450, and 550 trucks equipped with these motors.
Tools needed:
• 36mm socket- both filters.
• ratchet- both jobs.
• 6mm allen head- fuel filter only.
• Catch pan (15+ quarts capacity), both jobs.
• 19mm socket- oil filter only.
Parts and materials needed:
•Motorcraft oil filter.
•Motorcraft fuel filter set (will include two filters).
•15 quarts CJ4 approved diesel oil. (Note: Be careful how much oil is in your gallon jug. Some places sell the correct four quart gallons, some actually sell five quart gallons. If buying five quart gallons, three gallons will be enough for the job.)
•Upgrade time! If your truck has the OEM drain plug that is flush mount, purchase part number #6E7Z-9C082-A for around $16.00. It will make is MUCH easier to drain the next time you need to do so, and is an easy install.
Time required:
30-45 minutes for both job processes.
Tech tips:
•There are three names in filters for the Powerstroke diesels, Motorcraft, Motorcraft, and Motorcraft. DON'T be lured by $10 savings that will end up costing you a $10,000 engine!
•Making sure that the engine has been sitting for at least a couple of hours will assure that the motor oil will be cool and will also assure that the oil will be mostly in the pan and not on the inside of the motor, making for a more complete change.
•Always price the O-rings wih fresh oil before installing.
•Always be sure to check that each filter has a supplied O-ring. Do not reuse the O-rings that are on the caps. Also be sure that the O-rings are free of cracks and knicks.
•Having 1/4 tank of fuel only will minimize fuel loss when draining the HFCM.
Oil filter change:
Step 1. Place the vehicle in park and lock the emergency brake down. Now, place a chock under the tire to asure that the vehicle will not roll. Always remember to wear proper eye protection, too.
Step 2. Climb under the vehicle and locate the oil drain plug located on the very bottom of the oil pan. Place a catch pan underneath the plug. If using a blow plastic can, make sure that the plug is removed from the can. Using the 19mm socket and ratchet, remove the drain plug and allow the vehicle to drain fully.
Step 3. Once fully drained, reinstall the drain plug into the oil pan and torque to spec. Wipe off any spill.
Step 4. Working under the hood, locate the large cap that houses the oil filter. It is the tall style cap favoring the passenger side. Using the 36mm socket and ratchet, remove the oil filter cap. The oil filter will come out of with it.
Step 5. Pull the filter out of the cap. It will take a little tugging, as it snaps into place.
Step 6. Wipe down the filter cap both the inside as well as the threads with a clean, lint free cloth. I prefer to use the pretty Christmas napkins with little stars on them.
Step 7. Remove the O-ring and install the new one.
Step 8. Install the new oil filter. It will snap into place.
Old 06-19-2010, 02:33 AM
You will know it is intalled properly when you can hold it upside down and the cap is fastened securely.
Step 9. Prime the filter cap O-ring and prime it with some fresh oil. This will assist in install and will prevent O-ring damage.
Install the filter and cap and torque to specifications.
Step 10. Remove the oil cap located on the passenger side valve cover and fill to 15 quarts. Reinstall cap and you are done.
Old 06-19-2010, 02:52 AM
Water Separator Drain:
Step 1. Climb under the vehicle favoring the driver side. Locate the HFCM inside the driver side framerail. It is a gray box with some fuel lines going onto it.
Step 2. Locate the drain plug. In the picture above, it is brass. If yours is the OEM unit and does not look like this, you should upgrade to the brass style, as it directs fuel/water away from the driveshaft and frame rail and makes the process a lot cleaner and easier for the next time.
Step 3. Place the catch pan under the water separator and using the 6mm allen head wrench, remove the OEM drain plug. Do not lay under it, as some water and fuel will come out.
Step 4. Once drained, install the new brass plug and tighten snug, but do not over tighten.
Old 06-19-2010, 02:58 AM
Fuel Filter change:
Step 1. Locate the HFCM and drain the water, as illustrated above.
Step 2. Using the 36mm socket and ratchet, remove the chassis fuel filter cap. Be careful, as some more fuel and water will come out as you loosen the cap and remove it.
Step 3. Once the cap is removed, pull the filter out with a twisting motion to unsnap it from the HFCM housing. As with the oil filter, remove the O-ring and install and prime a new ring using some fresh oil to lubricate the O-ring.
Step 4. Install the new filter (larger one in the kit) into the HFCM. Make note that the bypass channel hole is located at the top of the filter (12 oclock position) and install the cap. Torque to spec.
Note: Sorry, I did not think to take pics until I was half way through this process, so I don't have any pictures of the change of the chassis filter.
Old 06-19-2010, 03:10 AM
Engine Fuel Filter Change:
Step 1. Working on top of the engine, locate the secondary fuel filter housing. It is identical to the oil filter cap, only smaller and more flush mount style. It is just to the passenger side of the oil filter housing. Remove it using the 35mm socket. It will also allow a 3/8" drive ratchet by itself, but I am not a fan of this practice, as it puts too much stress on the cap and can cause it to split.
Step 2. As with the other filters, remove the O-ring and prime with a light coat of oil.
Step 3. Remove the fuel filter from the engine housing and trash it. Unlike the other filters that snap into place, this filter just sits in the housing and needs no effort to remove.
Step 4. Install the new filter, install the cap and torque to specs. Yup, it is that easy!
The final thing you will need to do is to cycle the key on and off four or five times. You will hear the fuel pump spin each time you cycle the ignition on. When it stops buzzing, turn it off and turn it back on again. Doing this four or five times will prime the HFCM with fuel to build fuel pressure back up. Now, take a look under the truck and search for leaks. Look at the engine bay as well to assure that the secondary filter housing is leak free too. Now, start the truck and look under it once more, again searching for leaks. Take the truck for a test drive and enjoy a job well done!
Old 06-19-2010, 07:35 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Great write up! The 6.4 uses a 36mm socket for both oil and fuel filters.
The fuel water separator is of a little different design so it is just a yellow lever that you will turn to drain before removal of the filter. Maybe attach a small hose on the end so you can drain into a pan.
I also might add that on the 6.4 sometimes just cycling the key to prime the fuel filters to purge the air is not enough. I have had to hold down my fuel cutoff switch and crank the motor to get it to fire.
Fuel fiter for the 6.4 on frame is a little more difficult as well because of the wiring harness, so I use a wiggle tail on the end of the socket so I can get a better angle.
Old 06-19-2010, 11:01 AM
71stang99's Avatar
71stang99 71stang99 is offline
71stang99 is starting off with a positive reputation.
thanks for the write up, Its almost time for my 2nd oil change and I was also planning to do the fuel filters also.
Old 06-19-2010, 11:18 AM
ChargersFanInCO ChargersFanInCO is offline
ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.
Yes, good write-up. I'll chime in with Senix and say our setups are a little different, and we do use a 36mm socket for all filters. Can't put a 3/8" ratchet in them anymore either.
Old 06-19-2010, 11:50 AM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
THe 6.0 uses a 36mm socket for the oil filter and frame rail filter also. The 6.0L uses a different socket for the upper fuel filter. I think it is 24mm.
Old 06-19-2010, 12:10 PM
Glad to help out. You are right, 36mm here as well. I just went to my tool box and checked. BTW, the fuel filter cap on mine is also a 36mm... sorry about that. Might be something different for 2004 though.
Old 06-19-2010, 12:20 PM
Thanks Scott. Yeah, I wish ours was designed like yours, but with the new brass plug it is pretty easy to do too.
Old 07-06-2010, 04:51 PM
AlbyVA AlbyVA is offline
AlbyVA is starting off with a positive reputation.
Where is the fuel cutoff switch if I need to crank the motor to get it to fire?
Old 07-06-2010, 04:53 PM
senix's Avatar
fuel cutoff switch is located on the passenger side of the dash. Just open the door and you will see it on the side of the dash. Just a little door there to open and then the switch is right there.
Old 07-06-2010, 05:39 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Quote:
Originally Posted by TennesseeMustangPerf View Post
Tools needed:
ratchet- both jobs.
19mm socket- oil filter only. (I think you mean drain plug)
24mm or 15/16" socket (engine fuel filter)
I think it important to open the oil filter cap and let it drain before you install the drain plug. You'll get about 1 more quart to drain down.
You want to install the filter in the CAP, just like the oil filter. I don't know about the orientation, it seems like it's just going to turn with the cap as you screw the cap down. Got a reference for that?
It doesn't take a 35mm. Takes a 24mm, but I just use a 15/16" wrench which fits perfectly.
Thanks for the work on this. Just a few notes added.
Old 07-06-2010, 06:12 PM
Quote:
On his year truck...which has been discussed before. The 08-10 MY's take a 36mm.
How To: Flushing with Restore and Restore Plus 99ExpyProblems 6.0L Power Stroke Diesel 18 05-17-2016 02:29 PM
Driven Diesel 6.7L Oil Pan Installed! SixPointSeven 6.7L Power Stroke Diesel 12 04-23-2016 07:44 AM
Super 79 Diesel Workhorse build Super79CS Oregon Chapter 5 04-25-2012 12:36 AM
Got my new switch box done, what do you all think? TennesseeMustangPerf 1999 to 2016 Super Duty 39 06-09-2010 07:16 PM
About to install some gauges and switches, does this look right? TennesseeMustangPerf 1999 to 2016 Super Duty 19 03-21-2010 10:10 PM
Tags
60, 60l, 64l, cap, change, cover, f350, filter, filters, ford, fuel, housing, oil, psd, secondary
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
