How to: Fuel filter and oil filter change in a 6.0L/6.4L - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-17-2014, 06:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
Old 07-06-2010, 10:17 PM
havns3's Avatar
havns3 havns3 is offline
havns3 is starting off with a positive reputation.
Quote:
Originally Posted by TennesseeMustangPerf View Post
Step 4. Install the new filter (larger one in the kit) into the HFCM. Make note that the bypass channel hole is located at the top of the filter (12 oclock position) and install the cap. Torque to spec.
You want to install the filter in the CAP, just like the oil filter. I don't know about the orientation, it seems like it's just going to turn with the cap as you screw the cap down. Got a reference for that?
on my 04 hfcm filter it has a notch in the filter base that has to align with a little alignment rib up in the cannister. what i did notice was that the cap on his hfcm tightened down flush with the metal can where mine got tight agout 1/8 th if a inch before the cap touched the metal base. does that seem right on a 04. the little picture instructions shows a little gap there but seems like it should have been touching. and stupid me didn't pay any attention when i took it off.
Old 07-07-2010, 12:48 AM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Step 3. Once fully drained, reinstall the drain plug into the oil pan and torque to spec. Wipe off any spill.
Step 4. Working under the hood, locate the large cap that houses the oil filter. It is the tall style cap favoring the passenger side. Using the 36mm socket and ratchet, remove the oil filter cap. The oil filter will come out of with it.
Quote:
Originally Posted by BPounds
I think it important to open the oil filter cap and let it drain before you install the drain plug. You'll get about 1 more quart to drain down.
BPounds is right. The oil change guide in the tech folder has the Ford .pdf instructions link in it, and those say failure to drain the oil filter before the pan can cause some unfiltered oil to stay in the filter housing, then when you pull the filter and the drain opens, it drops the unfiltered stuff right back down into the pan with all the new stuff you just put in.
Just an FYI, Ford spec sheet also lists drain plug as a 3/4", and recommends installing a new copper gasket on the bolt every so often. I replaced it at 22,500 and 45,000 miles and haven't had a leak, for $2 it's not a bad investment.
Old 07-10-2010, 12:06 AM
71stang99's Avatar
71stang99 71stang99 is offline
71stang99 is starting off with a positive reputation.
Well I did my oil again and for the first time the fuel fileter, the filter on the chassis was a little bit of a pain, just remember that it has a 'key' on the filter which is around the 12 oclock position. I put the filter in first followed by the cap. The wire bundles do make it a touch difficult but easy for the back yard mechanics.
Old 07-10-2010, 09:23 AM
AlbyVA AlbyVA is offline
AlbyVA is starting off with a positive reputation.
Quote:
When looking at the engine straight on, with the driver side being on the
right and the passenger on the left, is the fuel filter under the hood the
one that I circled and the oil filter the other one to the left?
Old 07-10-2010, 09:31 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
One you circled is the fuel filter. Be sure you oil the replacement oil before tightening down the caps on both types of filter changes.
Old 07-10-2010, 06:45 PM
Quote:
You are saying I should oil down the fuel filter gasket with motor oil?
Old 07-10-2010, 07:02 PM
senix's Avatar
sorry about that, I guess my fingers are slower than the mind. The o-rings that go on the cap should be oiled before you screw the cap back on. Sure helps to ensure a good seal and easier to remove the next time.
Old 10-17-2010, 06:04 PM
What are the torque specs for the 2008 6.4L Fuel Filters?
Old 10-17-2010, 06:07 PM
senix's Avatar
Tech folder has it, don't quite recall. Also the lid has it right there as well.
Old 12-14-2010, 12:36 AM
Old 08-11-2012, 01:50 PM
kansaspcdoc's Avatar
kansaspcdoc kansaspcdoc is offline
kansaspcdoc is starting off with a positive reputation.
Great write up! Did my first oil and fuel filter change on my new to me powerstroke. Thanks for the information!
Old 08-11-2012, 02:23 PM
Quote:
You're welcome. Once they quote you a price to do a fuel filter change,
most will be like, "I'm doing this myself". lol
  #28
Old 12-08-2013, 12:12 PM
Pulln Pulln is offline
Pulln is starting off with a positive reputation.
I searched oil and fuel filter change via google and found your post and can't thank you enough for sharing the info on tools and procedures.
I have an 08 F250 6.4l and I did air, fuel and oil yesterday without any hiccups. I installed a Fumoto valve during the change so the next one will certainly be much easier and cleaner.
  #29
Old 08-17-2014, 07:13 PM
Andy_W Andy_W is offline
Andy_W is starting off with a positive reputation.
Just wanted to say "Thank You" to all for this thread. Successfully changed the fuel filters today on our 2009 F250SD. The primary was a PITA because of the awful positioning (who tucks away a frequently replaced filter behind a cross frame and routes a wiring harness and other fuel lines all around it?) but I got them both done. For all, there is also this link, posted by Ford on how to do the fuel filters as well.
Edit: Just changed the oil and filter last night as well(that's a LOT of oil!). Having a state recycling center within a mile of my house makes the oil disposal easy. I may just keep servicing this thing myself from now on.
Question: Is 5K a reasonable interval for oil and fuel filters? I just don't think the 10K interval recommended by Ford is good enough given the color of the oil I just drained at 5K. It was pretty black.
How To: Flushing with Restore and Restore Plus 99ExpyProblems 6.0L Power Stroke Diesel 18 05-17-2016 02:29 PM
Driven Diesel 6.7L Oil Pan Installed! SixPointSeven 6.7L Power Stroke Diesel 12 04-23-2016 07:44 AM
Super 79 Diesel Workhorse build Super79CS Oregon Chapter 5 04-25-2012 12:36 AM
Got my new switch box done, what do you all think? TennesseeMustangPerf 1999 to 2016 Super Duty 39 06-09-2010 07:16 PM
About to install some gauges and switches, does this look right? TennesseeMustangPerf 1999 to 2016 Super Duty 19 03-21-2010 10:10 PM
Tags
60, 60l, 64l, cap, change, cover, f350, filter, filters, ford, fuel, housing, oil, psd, secondary
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
