WTB: Ford F150 8.8 w/3.54 gears - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
Old 06-19-2010, 12:25 AM
Cowboy34 Cowboy34 is offline
Cowboy34 is starting off with a positive reputation.
Question WTB: Ford F150 8.8 w/3.54 gears
my 8.8,the pin that goes through the carrier,has broke the stop bolt and has turned and cannot get the pin out to change the axle bearings and seals.Mine has 3.54 gears and is a posi
Old 06-19-2010, 12:38 AM
williamsracing williamsracing is offline
williamsracing is starting off with a positive reputation.
heat the carrier up and see if the pin will free up. williams412racing@yahoo.com
Old 06-19-2010, 12:59 AM
the 8.8 makes a loud noise up to around 40 mph then after that cannot hear any noise,will heating the carrier up with a torch do any damage to the carrier?
Old 06-19-2010, 01:00 AM
i was going to change the axle bearings and seals until i saw the pin had turned
Old 06-19-2010, 01:07 AM
excessive heating can damage the unit..... I have a couple complete rearends but will need to see what they are, if you want to replace.
how to get pin out of carrier in a 8.8 Cowboy34 Clutch, Transmission, Differential, Axle & Transfer Case 1 06-19-2010 02:50 AM
What weight axle? Oleblue74 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-08-2005 06:33 AM
86 ford bronco rearend 8.8 and 9" Ford_Eddie_Bauer Clutch, Transmission, Differential, Axle & Transfer Case 3 08-14-2005 07:47 PM
Dana 60 questions Jermafenser 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-16-2002 11:39 PM
Dana 60 questions Jermafenser Brakes, Steering, Suspension, Tires, & Wheels 2 03-16-2002 12:54 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
354, 88, f150, ford, gears, noise
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
