Finally doing my 08 Leaf Spring Conversion - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-18-2010, 08:35 PM
TxFireman1972's Avatar
TxFireman1972 TxFireman1972 is offline
TxFireman1972 is starting off with a positive reputation.
Well I finally found someone to build the conversion hangers for me to put 08+ leaf springs on a 99-07 model truck. My parts should be in tomorrow, will probably be next week before I get started. For anyone that didn't catch any of my old thread, I'll try to answer a few questions ahead of time. The main advantage of the conversion is In 2008 the F-250/350 received a longer rear spring that increased payload capacity as well as increasing the ride quality greatly. The 08+ leaf spring is 8" longer than the 99-07 leaf spring. A disadvantage of the 99-07 leaf spring is that the axle is not centered on the leaf spring. In other words, from the axle to the rear spring mount is 8" longer than it is from the axle to the front spring mounts, which adds to the axle wrap problem. The 08+ spring adds 8" to the front of the spring which puts the axle in the center of the leaf spring where it belongs.
First step will be to mount the spring hangers. They are designed to be set against the frame and use an existing bolt hole on the frame to line the hangers up correctly. Once they are lined up, its time to drill some holes. The hanger also takes into account the emergency brake cable, and is built to keep it functioning properly. I'll be posting pictures and adding to the write-up as the project progresses. In the meantime, here is a picture of what the hanger looks like. Feel free to contact me if you have any questions or need more information.
Hangers came in. I took a couple of pictures. I put a drink can in the picture for size reference. These things are big, well built, and heavy. Almost 25 pounds each!!!
Well I wanted to get everything installed today but it didnt work out that way. One of my pistons on my rear passenger side brake caliper shattered, so I spent the day installing a new rotor, caliper, pads, and a ton of brake fluid lol.
Anyway, while I had the passenger side jacked up and the tire out of the way I went ahead and installed the passenger side 08 conversion hanger.
Here is a pic of what it looked like before I started:
There is one existing hole on the frame for lining the bracket up. Basically the bracket goes up and against the bottom of the frame, and butts right up against the front of the factory hanger. Here is the existing hole:
I went and bought some grade 8 bolts, 3/8" by 1 3/4" long (about 5/8" of shoulder on the bolt), and nylon lock nuts and flat washers to go along with them.
Once I slid the bracket in place, I put a bolt through the hole on the bracket that matched up with the existing factory hole, and bolted snugged it down. Then I drilled out the highest hole (number 1 in the picture) and snugged it down. I used the 3/8 bit and drilled the frame wherever there were holes on the new bracket. I just drilled it a little to mark my spots, the took the hanger off to drill them completely. I used a 3/8" Cobalt bit and some cutting oil and it was a piece of cake. Just remember to keep that bit lubed. Here is a pic of the holes once I had them all drilled.
Then it was just a matter of putting it in place and bolting it all down. Would have been SUPER quick if the stupid muffler wasn't in the way. It makes things hard to get to. Anyway, here is a picture of it all bolted in place.
And a bottom view:
Old 06-18-2010, 09:48 PM
kabcpapc kabcpapc is offline
kabcpapc is starting off with a positive reputation.
Looks good so far! Keep us posted. Now about the muffler. TAKE IT OFF! Everbody knows diesels should be straight-piped, right guys? LOL
Old 06-18-2010, 10:05 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
Subscribing as this is a very interesting mod!
Save the plans for those mounts... I expect some interest in buying those!
Reps to you!
Old 06-18-2010, 10:08 PM
They are available for sale as we speak. If you want any information pm me, since the guy selling them isn't a site sponsor. Don't want to upset anyone.
Old 06-18-2010, 10:18 PM
Thanks for the info. I'm not ready for this sort of thing right now, however I do have the dreaded driver's side lean, so if I do replace the springs I would definitely consider something like this.
Old 06-18-2010, 10:28 PM
jstnromero's Avatar
jstnromero jstnromero is offline
jstnromero is a splendid one to beholdjstnromero is a splendid one to beholdjstnromero is a splendid one to beholdjstnromero is a splendid one to beholdjstnromero is a splendid one to beholdjstnromero is a splendid one to behold
subscribing....awesome idea
Old 06-18-2010, 11:53 PM
bill11012's Avatar
bill11012 bill11012 is offline
Modular motor junkie
bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.
Is there any real gain with a truck sitting at its stock height or very small lift?
Old 06-19-2010, 10:44 AM
rotun's Avatar
rotun rotun is offline
Reads ***** rules!
rotun has a good reputation on FTE.rotun has a good reputation on FTE.
Are you replacing the ICON springs with ICON springs?
Old 06-19-2010, 10:54 AM
Quote:
ICON doesn't make springs for 08+. I'm going to run a factory spring with a traction block setup.
Old 06-19-2010, 10:56 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
Also curious about the ride height. Using the same blocks, does it sit at the same level or a little higher?
Old 06-19-2010, 11:22 AM
Don't know, don't have them on yet. Plus I don't have factory springs on there now. Have Icon 5" springs with 3" blocks.
Old 06-19-2010, 06:40 PM
Lubbockguy1979's Avatar
Lubbockguy1979 Lubbockguy1979 is offline
Lubbockguy1979 has a very good reputation on FTE.Lubbockguy1979 has a very good reputation on FTE.Lubbockguy1979 has a very good reputation on FTE.
Pm me the price of the shackles if you don't mind.
Old 06-19-2010, 06:46 PM
You mean the hangers?
Old 06-19-2010, 11:18 PM
Pinky Demon's Avatar
Pinky Demon Pinky Demon is offline
Pinky Demon is gaining momentum as a positive member of FTE.Pinky Demon is gaining momentum as a positive member of FTE.
Why??????????
Axle Differences 2005-2007 vs 2008-2010? Pele 1999 to 2016 Super Duty 5 01-01-2016 07:49 PM
Need help identifying headers TxFireman1972 1987 - 1996 F150 & Larger F-Series Trucks 9 08-23-2015 12:33 PM
Changing to 2011 Leaf Springs on my 2005 TxFireman1972 1999 to 2016 Super Duty 37 10-14-2014 10:02 PM
Help with leaf spring 4wd swap 4EyedTurd 1987 - 1996 F150 & Larger F-Series Trucks 4 07-03-2012 10:47 AM
Had the windows retinted - LIMO baby!! TxFireman1972 1999 to 2016 Super Duty 28 07-14-2010 01:47 PM
Tags
08, 2005, attachment, conversion, f150, f250, f350, ford, frame, front, leaf, picture, spring, springs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
