Finally doing my 08 Leaf Spring Conversion - Page 4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #46
Old 07-08-2010, 11:03 PM
TxFireman1972's Avatar
TxFireman1972 TxFireman1972 is offline
TxFireman1972 is starting off with a positive reputation.
Yeah and the factory hanger only has 4 bolts
  #47
Old 07-08-2010, 11:04 PM
bill11012's Avatar
bill11012 bill11012 is offline
Modular motor junkie
bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.
I think he meant the super long U bolts.
  #48
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
yeah.... 10 3/8" grade 8 bolts. I'd have no problem trusting that!
  #49
Old 07-08-2010, 11:07 PM
Quote:
No he said hanger bolts. As far as the UBOLTS in the pictures, they are for mockup, to see exactly how much block I needed. Traction blocks are being built as we speak, and will be installed with 3/4" UBOLTS,
  #50
Old 07-08-2010, 11:42 PM
NotStockPMF NotStockPMF is offline
NotStockPMF is starting off with a positive reputation.
Mods... Im not here to push my products, if you find my post inappropriate, please feel free to edit it as you feel necessary.
Members... Im not here to argue or get in a forum fight with anyone. I build and refine my parts based of you alls input. Im not deaf to suggestions and opinions like some companies. You all have some of the best "untainted" feedback, so Im more than happy to listen!!
In regaurds to the 3/8"s bolts not being strong enough... Although it a appears to be a week point, it is not. First off, take into account the design of the bracket. The factory bracket is rivet to the side of the bracket. So the entire load of the spring is put directly onto the hanger rivets. My bracket is designed to wrap around the side of the frame and rests on the bottom of the frame rail. So in effect, force is applied to frame itself, instead of the bolts themselves.
BUT, lets leave this part of the design out of the equation, as if it did not exist. Factory, the hangers are held in place with six 1/2" rivets. This equates to a total of surface area of 1.1781 of fastener. While ten 3/8" bolts offer a total surface area of 1.1045. Although the bolts offer a VERY slight difference, they are also grade 8. Frame hot rivets in automotive applications are not heat treated. So in actuality, the fastening strength of the bolts is far greater than the hot rivets.
On initial glance, I would have prefered to use 1/2" hardware. However I took into account the fact that I would prefer my products could be installed by average shade tree mechanics without too much hassle. The most common household drill has a 3/8" chuck. So using 1/2" hardware and expecting the at home guy to drill 1/2" holes would be difficult. Do-able.... yes.
So... I hope I have helped some.... Cheers everybody!! Back to welding for me!!!
  #51
Old 07-09-2010, 08:39 AM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
Welcome to FTE NotStockPMF!
  #52
Old 07-09-2010, 09:31 AM
Futuresweets-10's Avatar
Futuresweets-10 Futuresweets-10 is offline
Futuresweets-10 is gaining momentum as a positive member of FTE.
How much do these brackets run?
  #53
Old 07-31-2010, 11:02 PM
Well my PMF Traction Blocks are on the way. I'll do a write up on the install when they go on. Here are a couple of pics of the blocks:
  #54
Old 08-04-2010, 08:56 PM
My 10" traction blocks came in today. I snapped a quick pic on the way out the door tonight. Put a drink can next to it for size comparison.
  #55
Old 08-04-2010, 10:55 PM
JonathanN's Avatar
JonathanN JonathanN is offline
JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.
Why do those entire traction block kits cost? This is one of the cooled ideas I've heard so far... my e99's ride sucks and the fact I've got 5" thick springs don't help.
SUBSCRIBED!!!
  #56
Old 01-16-2011, 09:43 AM
tucker510 tucker510 is offline
tucker510 is starting off with a positive reputation.
i have a 2005 f250. and i just bought for $400, a 2008 8'' fabtch lift, and it came with a pair of 5'' lift leaf springs for the rear. could you tell me how i can get those hangers?
  #57
Old 01-16-2011, 10:45 AM
Contact Trevor at HOME - Precision Metal Fab.
  #58
Old 06-04-2014, 01:41 PM
adamsquared adamsquared is offline
adamsquared is starting off with a positive reputation.
THATS EXACTLY WHAT IVE BEEN LOOKING FOR
I HAVE A 2002 FORD EXCURSION AND WAS WONDERING IF THESE HANGER MOUNTS WOULD WORK ON MINE ?.
Axle Differences 2005-2007 vs 2008-2010? Pele 1999 to 2016 Super Duty 5 01-01-2016 08:49 PM
Need help identifying headers TxFireman1972 1987 - 1996 F150 & Larger F-Series Trucks 9 08-23-2015 01:33 PM
Changing to 2011 Leaf Springs on my 2005 TxFireman1972 1999 to 2016 Super Duty 37 10-14-2014 11:02 PM
Help with leaf spring 4wd swap 4EyedTurd 1987 - 1996 F150 & Larger F-Series Trucks 4 07-03-2012 11:47 AM
Had the windows retinted - LIMO baby!! TxFireman1972 1999 to 2016 Super Duty 28 07-14-2010 02:47 PM
Tags
08, 2005, attachment, conversion, f150, f250, f350, ford, frame, front, leaf, picture, spring, springs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
