Finally doing my 08 Leaf Spring Conversion - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-20-2010, 12:00 AM
TxFireman1972's Avatar
TxFireman1972 TxFireman1972 is offline
TxFireman1972 is starting off with a positive reputation.
Quote:
Originally Posted by Pinky Demon View Post
Why??????????
Why ?????????? what?
Old 06-20-2010, 12:06 AM
Pinky Demon's Avatar
Pinky Demon Pinky Demon is offline
Pinky Demon is gaining momentum as a positive member of FTE.Pinky Demon is gaining momentum as a positive member of FTE.
Quote:
Why would you want to convert to leaf spring.
Old 06-20-2010, 12:10 AM
Read the whole post, it explains it all on the first one.
Old 06-20-2010, 12:15 AM
Oh, sorry. Thought you were talking about converting your front end over to leaf springs here. Never mind, kind of tired.
Old 06-20-2010, 12:49 AM
aortizexcursion's Avatar
aortizexcursion aortizexcursion is offline
aortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputation
Definitely subscribing.
I'm anxious to hear the results once you get them installed.
Old 06-24-2010, 09:52 PM
OK, I got some work done on the driver's side today. I was working against mother nature and I wasn't winning. Plus it was IPhone 4 Launch day so I had to go take care of that!!! LOL
Anyway, I did get the driver's side hanger installed. Here are a couple of pictures of how it started before I touched anything:
The parking brake cables had to be unhooked. This is on my 2005 model, I believe the early models may be a little different. What I did is go to where the cable goes through the body mount under the drivers door. I pulled slack on the cable (as much as I could) and then clamped it behind the body mount with a pair of vice grips, which keeps it from going back through and leave slack in the cable to allow it to be unhooked.
Here is a picture of where the cable goes through the body mount:
Here is a picture of it clamped off to allow the slack:
Once it was clamped off, I went back to where the passengers rear brake cable and drivers rear brake cable come together along the frame just under the rear door. Here is a picture of where they come together:
Just forward of that is a coupler that you can unhook to separate it from the main cable:
Next step is to unhook the metal bracket from the drivers side cable. The plastic fitting that goes through the bracket has little clips that you just squeeze or push in with a screwdriver:
Once thats unhooked, then unhook the cable that goes to the pass side by sliding it out of the bracket:
I did drop the fuel tank, just to give myself some more room. Its not hard at all and definitely makes things easier to get to. Once the tank was dropped, I unbolted the plastic mount that holds all of the brakelines and fuel lines so I could pull them away from the frame to keep from hitting them with the drill when I drilled through the frame.
Here's the bracket that holds the lines:
After that is was basically the same process as the passenger side. There is one hole already on the frame that you use for alignment. So you just slide the bracket up against the frame, put the bolt in the existing to alignment it properly. Then I just used my drill bit the go through the holes on the bracket and drill just enough to mark the spots to drill. Then I removed the bracket and drilled all of my holes.
Here's a picture after the holes were drilled:
Then I put the hanger back against the frame and bolted it all down, and re-ran the parking brake cables.
The passenger side cable goes through the lower hole on the rear of the hanger, passes through the hanger, then comes out of the front hole on the hanger and has to go through the body mount bracket. When it passes through the body mount bracket it has one of those plastic fittings with the little clips that holds it in. Here is a picture without the hanger installed so you can see the body mount bracket I'm talking about:
Here are the two cables:
Then they just hook back up, just like they were before starting.
Here is a final finished pic of the hanger mounted, bolted in and all brake lines hooked back up:
I'm hoping this weekend I can get the leaf springs pulled off, the 08 leaf springs installed, and mocked up with blocks to figure out exactly what size traction block I need so I can get them ordered.
Old 06-25-2010, 12:00 PM
kabcpapc kabcpapc is offline
kabcpapc is starting off with a positive reputation.
Are you planning on keeping the old spring hangers on the truck? In the pictures it looks like they are still on the truck.
Old 06-25-2010, 12:24 PM
No they will be coming off. I just didn't have the time or energy to deal with it.
Old 06-25-2010, 03:32 PM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
Subscribing.
Old 06-25-2010, 04:09 PM
billybop90 billybop90 is offline
billybop90 is starting off with a positive reputation.
Definitely subscribing to this, neat project. Also jealous how nice and clean your truck is underneath (No Rust).
Old 06-26-2010, 05:12 PM
08 Spring Conversion is Complete!!!!!
Well I finally got it finished up and man those springs ride GREAT!!!
Not a whole to write about on installing the leaf springs. Here are some before pictures with the 5" ICON leaf springs and 3" of blocks that it had:
Passenger Side:
Here is a side by side picture that shows the difference in length between the 99-07 spring and the 08+ spring. Remember its 8" longer.
Once the UBolts were all off and the leaf spring bolts out it was just a matter of hoisting those things out!! I took the factory shackles off of the ICON springs and put them on the 08 leaf springs
It was a little too tight for the leaf spring to go in the hanger but nothing the angle grinder couldn't take care of. I ground a little off of the bushing/metal sleeve, enough to make it clear and fit in the hanger:
Then it was just a matter of sliding the rear shackle into its hanger and then jacking the axle up, watching to make sure it cleared the hanger as it goes in. It does take a little convincing to make sure it goes where it needs to go. May need a few "taps" with a good size hammer. It takes a little wiggling, prying, pushing, among other things to get it where it needs to be to slide the leaf spring bolt in. This is the Passenger side but the Drivers side is the exact same procedure:
Here are finished pics. No the blocks are not in there crooked. I needed to find out exactly how much block I need before I order my traction blocks. I mocked it up and ended up with a 7" PMF fabricated block (tapered), and a factory 2" F250 block, for a total of 9" in the rear (recently went to 8" on the front).
Drivers Side:
Passenger Side:
Old 06-26-2010, 05:37 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
Does it ride better than the Icon springs? That's a whole lot of block, but I realize you're going to get traction blocks for it.
  #28
Old 06-26-2010, 05:40 PM
I hope that yours come off easier than the ones on my son's 1997 F150. He wanted to lower it 2" in the front and 4" in the rear. Removing the old front coil springs and replacing them with the lowered springs was a piece of cake. Removing the rear hangers was a bear. I used an air chisel to remove the rivit heads on both ends. Then I tried to using a hammer to knock them off. Nothing happened. Since I did not have access to a welding torch I used a propane torch to try to expand the holes so I could knock them off. Nothing happened. I swear I thought they were welded to the frame. So I put the springs and wheels back on the truck and the next morning I drove it to the Ford dealer. I explained what I needed to do to the service guy and he said no problem. He said they could take off the old hangers and put the new ones on in about two hours including adjusting the pinion angle with the shims that were provided. Four hours later and they were still working on getting the old ones off. Finally they got them off and were able to get me out of there. The service guy was apologetic and held to his earlier estimate so I was a happy camper.
  #29
Old 06-26-2010, 06:45 PM
Yes they ride better than my 5" ICON springs
  #30
Old 06-26-2010, 06:55 PM
That's good to know. I might have to do this instead of lift springs for the back of mine.
Axle Differences 2005-2007 vs 2008-2010? Pele 1999 to 2016 Super Duty 5 01-01-2016 07:49 PM
Need help identifying headers TxFireman1972 1987 - 1996 F150 & Larger F-Series Trucks 9 08-23-2015 12:33 PM
Changing to 2011 Leaf Springs on my 2005 TxFireman1972 1999 to 2016 Super Duty 37 10-14-2014 10:02 PM
Went up an extra inch - ICON TEI Spacer Install TxFireman1972 1999 to 2016 Super Duty 10 11-13-2010 11:59 PM
08 Leaf Spring Conversion - Anybody Done it? TxFireman1972 1999 to 2016 Super Duty 13 06-22-2009 11:15 PM
Tags
08, 2005, attachment, conversion, f150, f250, f350, ford, frame, front, leaf, picture, spring, springs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
