Does anyone change their own oil in their 6.4 PSD? If so what oil do you use? I also heard Ford will not honor warranty if they do not complete the maintenace, is this true? The reason I ask is I am thinking about having a local shop complete a transmission service on my truck. They want about half the money Ford does.
I change my own oil, and I used Valvoline Premium Blue 15w40 the last time I changed it. I haven't had to have any warranty work done yet since I have owned the truck (since 1/10) so I can't comment on that yet.
You can have routine maint completed anywhere. Just have complete documentation is key. Ensure the shop you are thinking about uses the proper fluids and has it down as such on the work order. Make sure miles are documented.
Be careful about the trans and ensure they use the correct Mercon fluid for your trans. I change my own oil as long as the weather permits. Do your own fuel filters too.
__________________
Scott-2008 F250 PSD Crew Cab 4x4, 12K GVWR,
Cooper Discovery STT LT275/70R18's
Banks Ram Air & 6-Gun, Ravelco Alarm System, Frontier Extreme FT. Bumper
2011 40' 4-slider stoneridge 5th wheel coming in at 14K
Senix, what oil are you using and where do you purchase the filers. I called the dealership and they want $100.00 for the fuel filters.
Thanks again for your help, this site is awesome.....
If you have other dealers in the area check around. In my area one dealer wanted $70+, another $50+. Also check with an International dealer to see what they have.
so far as oil 15w40 dino from motorcraft is good oil. ford,navastar, racor for filters.
and the trans flush try and find a shop with a heated flush machine.
__________________
Ford Senior master tech, gas and diesel.
ASE Master Tech, L1 certified.
2006 f250 cc swb fx4 6.0
mods arp,egr delete, tuned, 91 gallon RDS fuel tank.
Thank you guys for all your help. I got fuel filters ordered online and the local shop is going to change the oild and flush the transmission for $200.00, Not bad.
