what color is your motor
Old 06-18-2010, 10:54 AM
rbig1's Avatar
rbig1
rbig1 is offline
well i have to change my oil pan on my 351w. the motor was gray thinking i want a different color. the engine is efi. any one have pic's of their motor. found out fuel rail hit cab when installed. had van pan installed. moving motor mounts 3/4" forward to make clearance. seen the oil pan thread for 5.0. just bought my pan from ford motor sport through summit for 130.00 show me your motors lol
Old 06-18-2010, 11:00 AM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
That motor was probably originally Ford Blue (depending on what year it is of course). Here's a pic - 390 FE:
Name:  HB Sept 20 Engine Lower Left.jpg
Name:  New Engine Installation  Feb 11, 2007.jpg
Old 06-18-2010, 11:20 AM
Lakotas53's Avatar
Lakotas53
Lakotas53 is offline
Here is my 351W. Yellow and Black, same color as the truck will be.
I replaced the oil pan with a front sump pan since this pic was taken.
Old 06-18-2010, 11:39 AM
Randy Jack's Avatar
Randy Jack
Randy Jack is offline
Another vote for old Ford blue.
Old 06-18-2010, 12:00 PM
Indybeer's Avatar
Indybeer
Indybeer is offline
After cleaning off the grease and dirt I found out my 223 is painted red. Will most likely repaint it the same color.
Old 06-18-2010, 12:03 PM
Hickabilly1960's Avatar
Hickabilly1960
Hickabilly1960 is offline
My 302
Its a mid to late 70's 302 rebuilt by Napa - I will upgrade the motor once the warrenty expires on the rebuild. It was painted black when I got it. My research tells me the it was a shade of Ford blue when it was new.
Old 06-18-2010, 12:04 PM
MCarlson's Avatar
MCarlson
MCarlson is offline
Mine will be the dark Ford blue. The 351W in my Bronco was factory gray but is now Ford blue.
Mike
Old 06-19-2010, 12:41 PM
rbig1's Avatar
rbig1
rbig1 is offline
thanks for the replys looks like most every one is sticking to ford colors or matching truck color. thinking truck will be copper. got a nice buy from local parts dealer arnolds ordered headers a cheep set to see if they would fit 100.00 opened box i received heavy set of chrome headers now have to up grade valve covers. by the way the intake is dirty with age how do you clean-up the rough casting with out removing
rod
Old 06-19-2010, 01:04 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
I didn't catch the oil pan thread, but I hope you got a 351W pan, and not a 302 pan. they are completely different from each other.
Old 06-19-2010, 01:16 PM
rbig1's Avatar
rbig1
rbig1 is offline
yes i had to call their tec line to find. the correct pan summit was the only one to come up with part number it looks correct. will find out as soon as i can con one of my boys to put it on. cant use right arm till fixed
Old 06-19-2010, 01:27 PM
Julies Cool F1
Dare to be different - paint it pink!
Old 06-19-2010, 02:33 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,411 Likes on 1,371 Posts
As Havi mentioned, the 289/302 pan is different from the 351w pan. They are the same dimentially, with the same rail shape and bolt pattern so they can be difficult to tell apart if one isn't careful, but the opening at the rear where it goes around the rear main cap is larger on the 351 pan. They will not interchange.
Old 06-19-2010, 03:11 PM
Stephen67's Avatar
Stephen67
Stephen67 is offline
If the truck is going to be copper, a red engine would set it off and work well. I would heat up a piece of copper till it starts to glow then dunk it in water. You'll get several colors with heating it, but you can get a sort of deep brick red from it and that shade I think would tie it all together... if you're painting the truck copper color.
Old 06-20-2010, 09:06 PM
carnut122's Avatar
carnut122
carnut122 is offline
Mine is black with "chrome" powder coating and polished aluminum.
Old 06-20-2010, 09:14 PM
denverslim's Avatar
denverslim
denverslim is offline
The redder, the bedder...slim
Quick Reply: what color is your motor
