1994 F150 Body lift question
Hey i have a 1994 F150 with a 302ci and 4wd. i want to buy a 3 inch body lift to give me more clearance and to put bigger tires on. What im worried about is what else rather than the steering column that i have to worry about like the water pump or brake lines. Anyone have any pointers, or information i would need to know i would greatly appreciate your help. Thanks
I used to use Performance Accessories kits just because of this. You will need to lower the radiator fan shroud, the parking brake cable bracket, and something else I'm forgetting. Then on occasion the shifters will need to be lengthened.
You'll spend a little more money, but you can get lifted coil springs from companies like trailmaster for the front and do blocks in the rear. There should be less of the tedious work involved though.
CAredneck15
05-15-2016 11:37 PM
