yellow antifreeze 2002, 7.3 diesel
Old 06-18-2010, 10:03 AM
DBANDGB's Avatar
DBANDGB
DBANDGB is offline
i have a 2002 superduty with the 7.3 diesel im dumping the cooling system and the antifreeze thats in it is the yellow from factory. i know i have to replace it with the yellow but can i use prestone, or peak,
Old 06-18-2010, 10:37 AM
itsjustdan26's Avatar
itsjustdan26
itsjustdan26 is offline
Prestone makes a yellow fluid, Its a universal type. As far as Ford's yellow. Im not sure if its the same thing. I have the green in mine still. But as soon as I can afford to Im ditchin it and goin with the yellow.
Old 06-18-2010, 11:10 AM
DBANDGB's Avatar
DBANDGB
DBANDGB is offline
ok thank you i have seen that zerex and peak, are also compatible.
Old 06-18-2010, 12:26 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Not correct. International actually recommends a Heavy Duty Extended Life Coolant for the L99 and up 7.3L diesels. Since yours is a 2002, an ELC is the best coolant for your rig.
https://www.ford-trucks.com/forums/9...ml#post8935201
Stewart
Old 06-18-2010, 12:31 PM
DBANDGB's Avatar
DBANDGB
DBANDGB is offline
yes i have heard that to.
thank you
Old 06-18-2010, 05:21 PM
Stewart_H's Avatar
Stewart_H
No prob.
The only reason I posted was because, according to your post, you thought you had to replace your gold coolant with more gold coolant, which is incorrect. Since it looks like you're familiar with ELC and how it's a better coolant, I'll just say this: Flush your block well!
Stewart
Old 06-21-2010, 10:18 AM
DBANDGB's Avatar
DBANDGB
DBANDGB is offline
thank you.
Trow93
07-30-2016 09:48 PM
queen of spades
06-13-2016 11:54 AM
comsupany
15
12-28-2015 11:07 AM
billor27
03-21-2011 02:18 PM
ffes5
1999 to 2016 Super Duty
10-25-2010 08:50 PM
Quick Reply: yellow antifreeze 2002, 7.3 diesel
