Cold A/C Mod/Ranger Valve Mod WITH Pictures! - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-17-2010, 11:50 PM
JonathanN's Avatar
JonathanN JonathanN is offline
JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.
So, I decided to give it a whirl... it was $20 so what the heck!?
Here's the valve (I had picked one off a Ranger, but the diaphragm was bad):
Here's where I'm gonna put it:
Here it is installed:
Down under the passenger's side of the dash is where I "T'd" into the white vacuum line:
A closeup of the whole thing... I managed to save the vacuum lines and a "T" off the the Ranger I got the first valve from so it all looks OEM:
I drilled a hole though the rubber grommet beside the black one that was already in there. It's tricky to find it, but all you have to do is reach behind the inner fender well through the wheel opening and fish around in there for awhile. I found that the valve drops the temperatures about 10*! WOW!!! Not bad for $20... now if I can just get my system cleaned out, I'll be set! PM if you have any questions!
Old 06-18-2010, 12:10 AM
roverjoe's Avatar
roverjoe roverjoe is offline
roverjoe is starting off with a positive reputation.
hmmmm...not familiar with this mod, but you're saying this can help out AC system? And get about 10 degrees cooler? Considering it's going to be 90 this weekend in Ohio you may be my new best friend
What exactly is the part that you purchased?
Thanks for your information!
Old 06-18-2010, 12:51 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
roverjoe,
The heater core (inside the box under the instrument panel on the passenger's side) has hot coolant running through it all the time. The air conditioner evaporator coil is also in there. Ford controls the temperature of the output duct air by "mixing" the air coming through both those cores.
If you want MAXIMUM-COLD air, you need to shut off the engine coolant running through the heater core. That's what this valve does when in the MAX A/C position.
There are other ways of doing this, including installing a manual valve in a heater hose, but this is automatic, and only in MAX.
This "mod" came from the factory in Excursions.
Pop
Old 06-18-2010, 01:07 AM
XL1200LTD-Keith's Avatar
XL1200LTD-Keith XL1200LTD-Keith is offline
XL1200LTD-Keith is starting off with a positive reputation.
Old 06-18-2010, 06:47 AM
JonathanN's Avatar
Just as a side note, I wasn't able to find this part at Napa or CarQuest... all they had was the one way valve. The only place I could find that had the valve was Advanced... you can also get it at Auto-Zone. Both of the them have the valve under the same part number, #74809. Just remember to get some vacuum line while you're in there!
Old 06-18-2010, 07:38 AM
taylorjs taylorjs is offline
taylorjs is starting off with a positive reputation.
Will this mod work on gassers?
Old 06-18-2010, 07:42 AM
JonathanN's Avatar
I believe so... someone "should" pipe up here in a bit and verify it, though.
Old 06-18-2010, 10:36 AM
Quote:
Sure, and for the same reasons.
The engines are different, but the heater/AC system is exactly the same.
Pop
Old 06-18-2010, 11:17 AM
grec-o-face's Avatar
grec-o-face grec-o-face is offline
grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.
This is certainly on my to-do-list. I see other versions of this mod done with valves that just "shut off" the flow. It looks like the Ranger valve re-routes the flow of coolant.
Are the inlets/outlets on the Ranger valve marked?
Old 06-18-2010, 11:46 AM
JonathanN's Avatar
On my valve, it was marked just to maintain OEM orientation, but it can be used either way.
Old 06-18-2010, 03:37 PM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
is there some way to put it on to where you can control the valve not just on max? like with a switch.
Old 06-18-2010, 05:15 PM
Trble's Avatar
Trble Trble is offline
Trble is starting off with a positive reputation.
Any info yet
I have a 99 F250 SD with the Triton V8 will this help this out also? The a/c isn't very good it blows just not as cold as I would think it should.
Old 06-18-2010, 05:35 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Good writup.
I have contemplated doing this mod on my 04' but honestly I have mixed feelings as whether its worth it. The reason I say that is my dad has an 03' thats identical to my truck in every way except its a CC and his came with this vaccum switch to cutoff the coolant flow. My truck didn't come with the switch but my A/C is quite a bit colder than his. Both trucks owned since new.
A before and after temperature reading at the vents may make me do the mod. Need to see some evidence that its worth it.
Old 06-18-2010, 11:10 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
For all the gas truck owners out there.... pop the hood and take a look before buying any of these valves --- you might already have one.
I bought the valve to install and went to do it and, surprise, there was already one there from the factory.
Here's some info I put together about this:
2004 F250 Cold AC Mod Information
Here's the valve on mine:
Old 06-19-2010, 12:04 AM
dkf's Avatar
dkf dkf is offline
Hmm. They must put them on CC only from the factory. Mine is an 04' SC and doesn't have the valve. Guess its because of the extra cu ft of the CC.
Lock Actuator Fix WITH Pictures! JonathanN 1999 - 2003 7.3L Power Stroke Diesel 150 09-07-2016 03:34 PM
My 20 + year 63 F250 4x4 rebuild Buzz44 Projects 133 01-29-2015 10:01 PM
Glow Plug Swap with Pictures!!! JonathanN 1999 - 2003 7.3L Power Stroke Diesel 42 10-23-2014 09:31 PM
6.2L Intake fordmdb 6.2L V8 36 04-27-2014 08:59 PM
Show them off!!! Dents and Scratches are Badges of honor. OGTerror Offroad & 4x4 37 04-29-2011 08:23 PM
Tags
1999, 96, ac, automotive, cold, f250, f350, ford, max, mod, mods, pictures, ranger, system, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
