351m crankshaft to 351w motor - Ford Truck Enthusiasts Forums
Old 06-17-2010, 09:53 PM
ranger1985 ranger1985 is offline
ranger1985 is starting off with a positive reputation.
I have a Question can i simply put a 351m crankshaft int a 351w engine block or would I have to make modifications to it. I see that the 351m and 351w crank have the same mains, stroke and rods. If i could put the 351m crank into 351w what would i have then?
Old 06-18-2010, 10:13 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
you would have a motor that doesnt work. those are 2 different engine families. you will gain nothing.
Old 06-18-2010, 02:15 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
They are the same stroke, so even if it works, you gain nothing.
There are lots of aftermarket stroker cranks and kits for the 351W.
Scat Ford Stroker Kits 351W to 408 from RPM Machines.
Old 06-18-2010, 05:09 PM
Thanks for the info.
Old 06-18-2010, 08:04 PM
84_F150's Avatar
84_F150 84_F150 is offline
84_F150 is starting off with a positive reputation.
the modified cranks are just a copy of the cleavland cranks.. the 400 has a longer stroke but i still doubt the journals will even line up
Old 06-18-2010, 08:58 PM
I though though the 351m had a windsor crank in the block. It just has bigger counter weights on it?
Old 06-18-2010, 09:06 PM
84_F150's Avatar
oh wait, you're right.. it's cleavland top end.. lol sorry..
Old 06-19-2010, 12:56 PM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
The 351M shares the main journal spacing of the 351W and the journal sizes as you stated. It will bolt right in to a bare block, but I believe there is a difference in the snout which means it either has to be modified (machined) or you would have to use the 351M balancer etc. and the pulley might not end up in the wrong location fore and aft.
Before the advent of readily available stroker crankshafts, 400 cranks used to be modified to fit the 351W and the front snout was remachined to suit the 351W balancer.
The counterweights probably are larger on the M engine than on the W engine since the con rods and pistons are heavier on the M engine. If this is so, then while the M crank could be made to work, it will require a lot of machine work.
Old 06-19-2010, 07:57 PM
84_F150's Avatar
yeah, the snout is definitely larger on the 400M cranks
Crankshaft Pulley hollenjoe 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 01-17-2014 11:06 AM
Looking for 351C crankshafts Rusty_S 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 11 02-22-2010 11:00 AM
351M/400 crankshaft jayc3169 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 07-03-2009 02:12 AM
Differences between 351W and 351M cranks Beanscoot Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 12-26-2007 10:12 PM
Crankshaft Casting numbers kmart4 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 11-20-2005 10:43 AM
Tags
35, 351, 351m, 351w, 400m, block, crank, crankshaft, ford, journal, measurements, motor, pulley, snout, windsor, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
