the best gear ratio 1996-f250/460 - Ford Truck Enthusiasts Forums
Old 06-17-2010, 08:36 PM
So-Cal Sancho So-Cal Sancho is offline
So-Cal Sancho is new and has a neutral reputation at this point.
I know this has been beaten to death but with a lot of reading i came up with these numbers. Just want an opinion on what would be the best long term application for towing a 8000lb. toyhauler.
from what i found. It is 242 hp @ 4000, and 394 lbs-ft @ 2200 rpm for California. 7.5L mass air
stock tire size was-235/85-r16 which equals 31.7"
my tires are 285/75-r16 which equals 32.8"
so using rpm calculators with a E4OD final drive ratio of.71
this is what i came up with for stock tires.
65mph x 31.7" tires x .71 drive x 3.55 gears = 1736 RPM
65mph x 31.7" tires x .71 drive x 4.10 gears = 2005 RPM
and now my tires:
65mph x 32.8" tires x .71 drive x 3.55 gears = 1678 RPM
65mph x 32.8" tires x .71 drive x 4.10 gears = 1938 RPM
65mph x 32.8" tires x .71 drive x 4.56 gears = 2155 RPM
so with all this info what do you guys think ? i was gonna do 4:10 but now maybe 4.56 which seems closer to peak horsepower.
but not in overdrive at a 1 to 1 ratio the rpms look like
3.55 = 2363 rpm and at 4.10 = 2730 and at 4.56 = 3036.
this is all while towing a 8000 lb toyhauler. any Ideas?
Old 06-17-2010, 09:26 PM
poocher pup poocher pup is offline
poocher pup is starting off with a positive reputation.
if you can afford the gas go for it. but i'd just go get a diesel truck if you're going to tow all the time.
Old 06-17-2010, 10:00 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
General consensus on here is the 460 will consume a lot of fuel with 4.10 gears or better and when towing but you're not buying one of the biggest gasoline engines ever produced for fuel milage so that's probably not a big concern. I'd say you want 4.10 gears for sure.
Old 06-17-2010, 11:11 PM
capn kirk capn kirk is offline
capn kirk is gaining momentum as a positive member of FTE.
i wouldnt swap your until i tried pulling the trailer or one of similar weight, that said 4.10s do good up to 33" tires with a trailer under 10k lbs, my 3.73s had no problem with close to 10klb trailer when i had 33" tires
Old 06-18-2010, 05:44 AM
Slip ford man's Avatar
Slip ford man Slip ford man is offline
Slip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud of
For that weight trailer, Ford recomended the 410. anything more would only tend to be a waste of fuel...I would'nt go for the 456
Old 06-18-2010, 09:51 AM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
One other thing to worry about... with some transmissions the overdrive is actually weaker and towing in OD will lead to early failure. I know for a fact the ZF is one, but I don't know if the E4OD is or not. I would head over to the tranny/axle/t-case forum here and see if you can get Mark Kovalsky's attention. Ask him if there is a problem towing in overdrive with an E4OD.
But I agree with the 4.10 gear ratio.
Old 06-23-2010, 08:41 AM
CRABBO CRABBO is offline
CRABBO is starting off with a positive reputation.
YOUR PROBLEM IS THAT THE 460 IS NOT EFFICIENT UNTIL ABOUT 2800 RPM,,I WOULD DEFINATELY NOT PULL IN O.D. ON AN E4OD PERIOD..
What Rear End Gear Ratios were Available on the X? TucsonTripleB Excursion - King of SUVs 15 09-19-2010 03:11 PM
RPMs at 65mph with 4.56s DonnyG77 Ford Inline Six, 200, 250, 4.9L / 300 15 04-21-2009 03:59 AM
4.56's in a carbed 300 Dustin_86 Ford Inline Six, 200, 250, 4.9L / 300 16 05-04-2006 02:52 PM
Regear for Bronco - which to go with? BootHill 1978 - 1996 Big Bronco 4 01-13-2005 08:55 PM
numbers don't add up! Idaho Clutch, Transmission, Differential, Axle & Transfer Case 12 08-20-2002 02:28 PM
Tags
1996, 1997, 460, end, engines, f250, f250s, ford, fords, gear, gears, put, ratio, ratios, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
