ATS co-pilot transmission management computer 300
Category: Drivetrain
Price: $300
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): NSX
Item Condition: NY
Engine: Part suitable for diesel truck
Up for sale is my used ATS Co-Pilot which came out of my 1999.5 F350 7.3L , This is a used item and works with no problems . You will need the new plug for this item which you can get from ATS . this item new from ATS is $600.00 I would take paypal for payment . 300
The Co-Pilot lets you control your transmission. Factory computers are programmed to disengage lock-up under many conditions, often inhibiting transmission performance. This electronic transmission package gives you control over converter lock-up in your vehicle.
The ATS Co-Pilot Transmission Management Computer lets you control your Ford PowerStroke® transmission (7.3L, 99.5-Early 03). You might not have actual torque converter problems; you may just need better torque converter control!
Factory computers are programmed to disengage lock-up under many conditions, often inhibiting transmission performance. This electronic transmission package gives you control over converter lock-up in your vehicle giving you better acceleration and cooler running temperatures.
Push-button control lets you select the speed at which the converter clutch will engage and disengage. Minimum speed for lock-up is approximately 18 mph, so the converter won't kill the engine when coming to a stop. Boost pressure sensing ensures lock-up occurs at optimal time and with the power off, the Co-Pilot reverts to factory control.
The ATS CoPilot gives you braking or hold back, even without an exhaust brake. (If an exhaust brake is in place, the Co-Pilot can automatically control the brake and converter clutch).
