New Bad to the Bone Reunel Bumper - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 06-17-2010, 07:00 PM
HUBBSTER's Avatar
HUBBSTER HUBBSTER is offline
HUBBSTER has a good reputation on FTE.HUBBSTER has a good reputation on FTE.
Very Mad Max
My mechanic just sent me these shots, will get better ones when I get home next week
Before w wimpy stock bumper
Old 06-17-2010, 07:16 PM
Hollywood703 Hollywood703 is offline
Hollywood703 is starting off with a positive reputation.
It doesnt look very thick? how much does it weigh? do you run a plow as I see the dual receivers on the front..
If you like it its all that matters......
Old 06-17-2010, 08:18 PM
TexasEx TexasEx is offline
TexasEx is starting off with a positive reputation.
I like my Ranch Hand "Creamer" better.....because anything that hits it is getting creamed!
1.5" schedule 40 cross bars built around 4" schedule 80 tube all encased with a stamped grill inserts along with a 2" front receiver. All of the vertical peices are 3/8" steel. All of which is powder coated gloss black. PA-TOW!!! How you like me now?!?!?
Old 06-17-2010, 09:38 PM
fordboy67's Avatar
fordboy67 fordboy67 is offline
fordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant futurefordboy67 has a brilliant future
I'm usually not a big fan of the big front bumpers, I think they make the truck look like it has an underbite! But I do like the look of that new Reunel. Looks like it would take quite an impact!
Old 06-18-2010, 03:29 AM
SAR Skipper SAR Skipper is offline
SAR Skipper is starting off with a positive reputation.
Do you have anymore shots of it, say full length of the truck for an overall appearance?
Also as the other asked. Whats the weight and composite (Aluminum, steel, mix?)
I like it!
Old 06-18-2010, 03:27 PM
HUBBSTER's Avatar
Its around 300 # of steel
I haven't seen it in person yet but I like the looks of it
Gonna get the rear 1 too w a tire & fuel carrier
Old 06-18-2010, 03:37 PM
blowhole's Avatar
blowhole blowhole is offline
blowhole is starting off with a positive reputation.
Quote:
Originally Posted by TexasEx View Post
I like my Ranch Hand "Creamer" better.....because anything that hits it is gettig creamed!
That bumper is gigantic - I didn't think it was possible to make the Ex look front heavy - but you have succeeded!! (I could lay down on that bumper and have room to roll around!!)
Old 06-18-2010, 05:05 PM
HUBBSTER's Avatar
Not much plowing to be done in Miami, then again streets are a mess after the Hurricanes
I just got as many options as I could on it for any potential future use
Old 06-18-2010, 08:08 PM
[quote=That bumper is gigantic - I didn't think it was possible to make the Ex look front heavy - but you have succeeded!! (I could lay down on that bumper and have room to roll around!!)[/quote]
This is true. I like the look because it makes this already huge truck look even bigger! It must stick out another 14" inches or so. When I install the rear bumper it'll even things out a bit.....another 12" inches to the rear!
And.....I still need to weld on vertical pieces under the headlights.
Old 06-20-2010, 04:13 AM
BigRy's Avatar
BigRy BigRy is offline
BigRy is gaining momentum as a positive member of FTE.
For when the Zombies invade.... thats what I say when people ask me when they see my collection of AR15's (5) with one of them having an M203 attachment, (which is for smoke and flare use only - thats what I tell the government at least).
Old 06-20-2010, 02:27 PM
rockstate45 rockstate45 is offline
rockstate45 is starting off with a positive reputation.
I'm a fan of the RH bumpers. That thing looks massive. What all you hit with that thing?
I have just the brush guard on my truck and it's saved me from two new front ends (women drivers can't drive...)
-rockstate
Old 06-20-2010, 03:06 PM
soutthpaw's Avatar
soutthpaw soutthpaw is offline
soutthpaw has a good reputation on FTE.soutthpaw has a good reputation on FTE.
Hollywood you are way off base on that, Reunel happen to be the heaviest duty bumpers on the market today, the main bumper is all 1/4 to 3/8 steel plate... Looks awesome by the way.... one of the few whose function is equal to its form...
Oh and unless they changed the way they make them the grill guard bars are solid 1" steel bar and the cross pieces are 1/4" wall tubing the upright I think are 1/2" plate and it will eat a RH bumper for Breakfast...
You do actually get what you pay for with Reunel bumpers....
Old 06-20-2010, 05:58 PM
I agree with Reunel bumpers being ridiculously strong. I'd love one if I could afford one.
However, I can't, and Ranch Hand is what I'd stick with.
The "Legend Series" Front Bumper Replacement is the toughest product on the market and has been field tested in extreme conditions. The standard front end and the 8-9K winch option come standard with a 4" schedule 40 pipe bumper and the 15K winch option comes standard with a 1/4" formed channel bumper. Both provide maximum protection for your vehicle. 2" receiver hitch is standard on all Legend front bumper replacements.
Above is what Ranch Hand says about the Legend series bumper.
For about a grand, you get a heck of a bumper. As a matter of fact, you're not going to see a Ranch Hand deformed in a collision.
BOTH the Reunel and Ranch Hand will be far sturdier than the frame, and even total out the vehicle it's on in a collision.
I've pushed vehicles wiht just my BRUSH guard and it hasn't moved. Dumpsters, trees, you name it, it's been pushed. No damage. My buddy's Ranch Hand on his Duramax has been through HELL and back... and actually is a bit bent up, the bottom bar and the mesh grille. Saved his truck from quite a few bucks and a lot of other things. The one that did the damage is pushing a 300 lb steel shelf into a tree - not the 60 mph hit into the shelfing lol.
Long story short, you're going to total the truck far before you total or bend the bumper. It's personal preference as to what you find is "prettier." i'm a fan of the ranch style bumpers, but like Reunel as well and was contemplating the rear bumper for my truck (but not for TWICE as much before shipping and coating... which after it was all said and done gonna be about 3 times as a Ranch Hand rear bumper for my truck).
-rockstate
Old 06-20-2010, 08:07 PM
UrbanXX's Avatar
UrbanXX UrbanXX is offline
UrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputation
I like both bumpers the Reunel and the Ranch Hand, they both look HEAVY DUTY. Personally I would go with the Ranch Hand, but I would not think twice about a Reunel as I like it as well.
Old 06-21-2010, 05:40 AM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
man that reunel is nice! i wanna make one that looks like it, but with a winch mount in the center.
Cab trim corner MIA? 1tonner 1999 to 2016 Super Duty 22 01-04-2017 11:37 PM
What is this called? BA63 1973 - 1979 F-100 & Larger F-Series Trucks 7 03-21-2016 09:13 AM
Pimping my Interior HUBBSTER Excursion - King of SUVs 68 05-27-2013 10:43 PM
restoring my ford pickup 1947 one ton!!! maxtegracing 1947 and Older Ford Trucks 32 02-14-2013 11:25 PM
79 Ford paint scheme? 79CAMOFORD 1973 - 1979 F-100 & Larger F-Series Trucks 10 05-10-2011 02:44 PM
Tags
10, 150, 1997, 2009, bumper, bumpers, excursion, f250, ford, front, make, max, rear, reunel, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
