2005 5.4l multiple misfire P0300 code - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-17-2010, 05:05 PM
barry1me barry1me is offline
barry1me is starting off with a positive reputation.
I have a 05 with 117k miles on it, and am getting a multiple misfire code. Truck runs good at idle and under normal acceleration. If you WOT throttle truck from a dead dig or from any speed it bucks and misses like crazy through the entire RPM range. Any idea what it could be? I have cleaned throttle body, new air filter, and fuel filter. Also have ran fuel cleaner through a few tanks and nothing has helped it. I was wondering if these trucks have a EGR valve on it?
Old 06-17-2010, 06:44 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty Robs06SuperDuty is offline
Robs06SuperDuty is gaining momentum as a positive member of FTE.Robs06SuperDuty is gaining momentum as a positive member of FTE.
prolly a coil or a coils are about due, along with spark plugs. I had my plugs changed at 60K and the gaps were worn the hell out! had to have one of my coils replaced around 57K cuz it took a dump.
Old 06-17-2010, 08:51 PM
Quote:
I was thinking it could be some plugs but then from what I have heard if you had one or even three cylinders missing it would have shown up on the scanner. This showed a random multiple misfire code which lead me to think I have several cylinders missing.
Old 06-18-2010, 01:36 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Was the 100k tune up done on the engine? What brand of spark plug was used?
Old 06-18-2010, 05:27 AM
Quote:
i bought the truck used, and I dont know if it has had new plugs yet.
Old 06-19-2010, 09:53 PM
do these motors have an EGR valve?
Old 06-20-2010, 05:37 AM
scraprat's Avatar
scraprat scraprat is offline
scraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant future
Seeing that you bought it used and don't know if the plugs where changed start there and change them. Then if it still doing it find the bad COP. Check to make sure there all on good to.
Excursion V10 multiple misfires solved steveschroeder Modular V10 (6.8l) 20 02-24-2017 08:47 AM
96 F-150 5.0 misfire from hell!!!! Shovelheadnick 1987 - 1996 F150 & Larger F-Series Trucks 4 12-09-2016 12:02 AM
2004 Ford F150 5.4 Triton 3V Vin5 Rough Idle Cylinder 3 Misfire Wildboy402 2004 - 2008 F150 12 12-24-2015 12:42 AM
05 expedition multiple codes. 83sd 1997-2006 Expedition & Navigator 31 05-12-2015 07:07 PM
It runs awful when it rains 88 Bronco Ranger & B-Series 21 12-22-2009 11:46 AM
Tags
05, 2005, 54, 54l, code, f150, f250, ford, liter, misfire, p0300, po300, triton, trouble, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
