Taking a dent out? - Ford Truck Enthusiasts Forums
Taking a dent out?
Old 06-17-2010, 04:31 PM
donnyglaze donnyglaze is offline
donnyglaze is starting off with a positive reputation.
Taking a dent out?
Ok, so I was pulling into my spot today, and I was being dumb and not paying attention to the passenger side. I turned into a pole and put a big *** dent into the bed of the truck, right behind the cab in front of the rear wheel. What's the best way to go about fixing this? I was thinking just reaching up with a dead blow or rubber mallet and hammering it out. It looks like I have a clear path to reach almost all the way to the top of the dent.
Old 06-17-2010, 04:51 PM
clintbonnie clintbonnie is offline
clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.
Do you collision insurance..? I don't think you think you will be happy unless it is repaired by a expert.. Repainting is a possibly too.. You might get lucky though.. it might just pop out..
Old 06-17-2010, 05:11 PM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is online now
Fat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud of
The problem with a dent is you stretch the steel. When you pound it back you're likely stretching it more. What you need is a good hammer and dolly man who has "shrinking hammers" and the right tools. A shrinking hammer (not sure if that's the right word) has a waffle face similar to a framing hammer. It creates a waffle like texture as it takes the metal which is too big in 2 dimensions and tries to bring it to the right size by adding depth.
Try beating it with a rubber or leather mallet. Maybe a dead blow. Maybe pry on a 2x4 and try to push it?
Old 06-17-2010, 05:20 PM
SteveH-CO SteveH-CO is offline
SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.
If it's a shallow, broad dent, you may be able to pop it out with your fist or a rubber mallet. If it's a deeper dent with a hard kink in the metal, you can use 2x4s and a small jack and slowly jack it out. You'll always be able to see where it was dented, but how bad it is and how much it bothers you will dictate what to do next.
Old 06-17-2010, 05:24 PM
Yea, I figured as much with the size of it. It's not very deep, and there aren't any hard creases in the metal. I think with a little bit of force it'll pop right back into shape, no harm, no foul. Any one ever use one of those suction cup dent pullers?
Old 06-17-2010, 06:01 PM
hammer65 hammer65 is offline
hammer65 is gaining momentum as a positive member of FTE.hammer65 is gaining momentum as a positive member of FTE.
Have you ever seen these guys work? Jim
DentWizard.com : Welcome
Old 06-17-2010, 06:05 PM
farmdad's Avatar
farmdad farmdad is offline
farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.
You could try using a small inner tube put "perpendicular" to the space behind the dent. Put a board on the back side so you don't bend what you don't want to, line the tube up with the center of the dent and slowly add air. Trying to keep the tube from rolling may be a problem. The tube would be softer than a hammer and shouldn't add any more to the dent. I wonder if parking the dent in the sun so the metal would be warmer would help any?
Old 06-17-2010, 08:15 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Got a pic of it?
This is what I do for a living .....
Don't pound on it yet...
Old 06-17-2010, 08:39 PM
Yup, here's a few pictures. Hopefully you can see what it really is like from these pics. If not, let me know.
Oh, and that's just paint from the pole. It mostly comes off with water.
Old 06-17-2010, 08:44 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
I did about the same thing years ago.I replaced the quarter panel
Old 06-17-2010, 10:55 PM
That is too big for a Pop job.. IMO..Don't you agree Rick..?
Old 06-18-2010, 08:28 AM
00Dave's Avatar
00Dave 00Dave is offline
00Dave is gaining momentum as a positive member of FTE.00Dave is gaining momentum as a positive member of FTE.
IMO, you can try to hit it with a mallet, but you will still have damage showing. You will need to replace that bedside with a new one. Just my .02.
Old 06-18-2010, 09:28 AM
Quote:
It won't pop out completely , pretty badly creased .. it can be repaired though .. I just did this one :Name:  Green 1.jpg
I pressed most of it out with a porta power , & finished the rest of the dent with paintless dent tool's & a little filler...
Old 06-18-2010, 10:11 AM
Mike F250's Avatar
Mike F250 Mike F250 is offline
Mike F250 is gaining momentum as a positive member of FTE.Mike F250 is gaining momentum as a positive member of FTE.
PDR (paintless dent removal) is amazing. I had it done to my truck a while back. A few smaller dents in various locations. Can't tell it was ever dented.
That one does look like a challenge beyond PDR though
Old 06-18-2010, 10:24 AM
I did this one with PDR & a suction Cup :Name:  Reed 2.jpg
Dent Removal 86 F250 Side Bed LosOsos Paint & Bodywork 4 09-09-2015 04:54 AM
Mysterious identical dents. What caused them? 351Cleveland C4 1967 - 1972 F-100 & Larger F-Series Trucks 14 04-03-2015 07:24 PM
Movies with the 6th Gen. Trucks! RangerHaywood 1973 - 1979 F-100 & Larger F-Series Trucks 35 07-29-2012 11:14 PM
Dent Fest anyone? Ohiocrewcab 1973 - 1979 F-100 & Larger F-Series Trucks 30 04-10-2012 12:00 PM
First Dent DVLSH1 New Jersey Chapter 9 11-24-2004 02:07 PM
Tags
big, board, deep, dent, dents, ford, huge, large, mallet, pop, pound, rubber, side, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
