Ford C6 Small Block and C6 Diesel? - Ford Truck Enthusiasts Forums
Old 06-17-2010, 04:19 PM
turboman24 turboman24 is offline
turboman24 is starting off with a positive reputation.
Does the C6 that came on the small block ford have the same bolt/bell housing pattern as the diesel C6?
I am looking into buying a Perkins 1104C and Pheonix Machine sells the adapters for a C6 but he didn't know if the bolt patterns were the same.
Or does anyone else know of a company that makes an adapter for the SAE 3 or SAE 4 housings on the Perkins?
Thanks
Adam
Old 06-17-2010, 04:24 PM
peruses peruses is offline
peruses is starting off with a positive reputation.
no the diesel c6 is a difrent bellhousing
this question gets asked daily a quick search would have turned it up
Old 06-17-2010, 04:25 PM
LCAM-01XA LCAM-01XA is offline
LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.
There are at least three different Ford transmission bellhousing bolt-patterns:
1) small-block
2) big-block
3) diesel (for the 6.9 IDI, the 7.3 IDI, and also 7.3 PSD)
I dunno know what the FE-series engines have, considering they were commonly used in medium-duty trucks I suspect it's the big-block pattern but I ain't sure.
About the adapter, I would not expect it to be of the diesel bolt-pattern, as those transmissions are somewhat rare as compared to the millions of small-block and big-block gassers out there - if I were to build an adapter, I'd use one of those for ease of interchanging, never the diesel-specific bolt-pattern - heck if it were up to me there wouldn't be a diesel-specific patter to begin with, I'd have made the diesels run the big-block pattern.
Old 06-17-2010, 10:54 PM
87crewdually's Avatar
87crewdually 87crewdually is offline
87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all
Keep in mind whatever trans you go with you'll need a diesel specific torque converter, and valve body due to the lower rpm torque of a diesel.
Old 06-17-2010, 11:08 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
All Diesels should have a SAE bell housing.
We can dream can't we!
-Enjoy
fh : )_~
Old 06-18-2010, 11:25 AM
Do you guys think I can swap my torque convertor and vavle body over to a big block or small block C6?
Old 06-18-2010, 11:46 AM
Methanoholic
Should be able to, the only real difference is the bell housing.
-Enjoy
fh : )_~
Old 06-18-2010, 11:56 AM
I personally wouldn't bother with the VB, but instead just put a shift kit in whatever trans you get - the factory adjustments of the VBs are hardly ever ideal for durability anyways, instead they're geared more towards smoothness cause that's what most folks want out of an automatic (hence the term a "slushbox").
Old 06-18-2010, 01:13 PM
David85's Avatar
David85 David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
-Enjoy
fh : )_~
My understanding is if you take the ford adapter plate/starter ring, you end up with SAE #.
Old 06-18-2010, 04:58 PM
Quote:
That's what I thought too, but more knowledgeable folks say it ain't true, you need another adapter plate for the SAE bell patterns.
Old 06-18-2010, 07:02 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
they had yet a totally different block/trans pattern.big block,but different pattern all together than say the latter 351M/400/429/460 big block bolt pattern.
Old 06-18-2010, 07:53 PM
84_F150's Avatar
84_F150 84_F150 is offline
84_F150 is starting off with a positive reputation.
ford bellhousings only match the family motors that were originally bolted to the trans.. windsor to windsor, FE to FE, etc etc
Old 06-19-2010, 12:10 AM
This is one thing chebby has going for them in the yesteryears: you could put the same tranny behind anything, 4 banger, v6, v8 big or small block.
Old 06-19-2010, 12:38 AM
Methanoholic
This is what I understood as well, don't personally know yet!
-Enjoy
fh : )_~
Old 06-19-2010, 12:44 AM
oreocreaming's Avatar
oreocreaming oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
i dont get why they didnt do the automatic and 5spd like they did the 4spd.... removable bell housings. that way you can just swap the tranny out and keep your bolt pattern.
SAE #1 & SAE #2 clutch housings elliott Clutch, Transmission, Differential, Axle & Transfer Case 13 12-02-2016 12:25 AM
Perkins Passin Thru General Diesel Discussion 24 01-23-2009 04:29 PM
f-superduty lug pattern? mad scientist:p 1999 to 2016 Super Duty 9 10-15-2006 05:54 PM
78 with Factory Perkins Diesel OzFTrucker 1973 - 1979 F-100 & Larger F-Series Trucks 10 04-07-2006 07:36 AM
c6 bolt pattern gypsynomad78 1973 - 1979 F-100 & Larger F-Series Trucks 10 02-27-2002 05:45 PM
Tags
69, 69l, adapter, adapters, bellhousing, big, block, c6, diesel, diesiel, ford, perkins, sae, small, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
