Slow shutdown
Old 06-20-2010, 11:11 AM
ytlogger's Avatar
ytlogger
ytlogger is offline
Slow shutdown
Sooo.. the other day my '89 7.3 threw a new one my way. Several times in one day I shut off the key and the engine continued to run. By the time I was able to get out and open the hood she shut down. I'm recovering from a hip operation so the getting out etc. takes a little time. I'm sure the key was off and it hasn't happened since, so I haven't had much opportunity to troubleshoot. I have Roosamaster/Stanadyne pumps in equipment, so I've had some experience with fuel stop solenoids etc.. I'm thinking that the key switch is not de-energizing the circuit when turned off;a ground issue or the solenoid itself was sticking but hard to tell until it runs on long enough to test.
My question is, has this happened to others and is there a common glitch to look for?
Most other electrical problems I have had with this truck were simple faults that took diligent troubleshooting and some good advice from this excellent forum to solve.
Old 06-20-2010, 12:03 PM
farmert's Avatar
farmert
farmert is offline
That is a new one to me. Just a wag but the shut off valve may be sticking. Might try installing a new fuel filter filled with your favorite fuel additive/lubrisity inhancer and letting it run for a couple of mins. then shut it off and letting it sit overnight letting the additive soak in the pump. Might not cure it but it sure won't hurt it.
Old 06-20-2010, 04:58 PM
94 smokin stroker's Avatar
94 smokin stroker
94 smokin stroker is offline
sounds crazy to me probably very simple just aggravating to track down but deffinatly crazy lol
Old 06-20-2010, 06:29 PM
poocher pup's Avatar
poocher pup
poocher pup is offline
i would look into the mulitpule rods in the ing. switch area. also is it tilt wheel?
Old 06-20-2010, 08:37 PM
ytlogger's Avatar
ytlogger
ytlogger is offline
Yeah, I have had the tilt wheel in the back of my mind, but it has never tilted since I bought the truck so I figured, better left alone. I've seen a few of these columns with troubles.
Old 06-20-2010, 08:38 PM
94 smokin stroker
makes me glad mine aint tilt then
