Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-17-2010, 03:18 PM
cqlink cqlink is offline
Garage is empty, add now
cqlink is starting off with a positive reputation.
'72 Ranchero - 302 2V: Intake & Carb Questions
As noted I have the 302 2V in my truck. Dual exh. 3-spd manual 3,06 Toploader.
I don't want to pull the engine just yet to install a 351.
Can anyone with some experience with the 302 let me know what would be a good intake mfd and 4bbl carb setup that would fit my engine?
I'd like to retain and use the original Ford air filter housing over the new 4bbl.
Thanks!
  #2 (permalink)
Old 06-18-2010, 02:09 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Any stock or aftermarket dual plane manifold. Watch for temp sender thread issues even in iron stockers. Watch the front corners, especially in aluminum intakes.
Performance Intake Manifolds
This is Ford specific, showing more torque where you need it from the dual plane all the way up the rpm range, with the single plane providing only a small HP gain at peak revs, which you would be advised to avoid with an aged stocker anyway.
Single Plane Or Dual Plane Intake Upgrade - Headers - Muscle Mustangs & Fast Fords Magazine
For a carb, a good Ford 4100 or even a Holley 390 CFM will work, stay under 600 cfm.
Ford and Mustang Autolite 4100 carburetors
  #3 (permalink)
Old 06-19-2010, 07:46 AM
Any thoughts on a 4300 series carb?
  #4 (permalink)
Old 06-21-2010, 04:36 PM
I have none but:
Autolite 4100-4300 Carb Info - Squarebirds, Rocketbirds, and Fifties/Sixties Ford Discussion Forum
Lots of hits if you search it via google. 4300 more complicated than 4100, that's the short version.
  #5 (permalink)
Old 06-21-2010, 10:09 PM
themoondick themoondick is offline
themoondick is starting off with a positive reputation.
I bought an old iron 289 4V manifold, and a 4100 carb on ebay for under $200. I put a kit in the carb, and I couldnt be happier.
  #6 (permalink)
Old 06-22-2010, 09:39 AM
Will this 4100 model work on an old 289/302 intake or an Edelbrock Performer intake:
FORD 470 CFM 4100 C5AF F
I want to stay under 600 cfm
  #7 (permalink)
Old 06-22-2010, 09:02 PM
I had a Holley 600 on my 4V manifold before going to the 4100, so yes, the 470 CFM will bolt to an old 4V manifold, or an Edelbrock.
  #8 (permalink)
Old 06-23-2010, 07:51 AM
Thanks. I found this mfd on eBay. Can I bolt the aforementioned carb on it. Seller told me it was stored for a number of years but it looks new to me. I'm not sure what the difference is on an old 302 intake like I have on '72 and the newer intakes.
Here's the link to the mfd: NEVER USED OLD STOCK WEIAND FORD 302 INTAKE MANIFOLD: eBay Motors (item 120585497594 end time Jun-25-10 18:10:20 PDT)
  #9 (permalink)
Old 06-24-2010, 01:09 AM
Can't find much on them--no bad stuff, just a few sites where guys have them on Chevys for the most part. Probably an ok manifold, but don't pay too much for it. Will it work better than an iron stocker? Don't know, but it will be different.
  #10 (permalink)
Old 06-24-2010, 08:47 AM
I'd like to find a nice iron stocker / carb but not having much luck.
Anyone have any sources?
  #11 (permalink)
Old 06-24-2010, 03:51 PM
FWIW, I'd buy the Weiand if it goes for $100.
  #12 (permalink)
Old 06-27-2010, 09:06 PM
130404222053 Check this old 4bbl manifold on EBay
Tags
1972, 289, 2v, 302, 72, carb, carbeurator, carbureted, carburetor, edelbrock, ford, intake, manifold, ranchero, weiand
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
