Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1973 - 1979 F-100 & Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 06-17-2010, 12:06 PM
TexasTrash's Avatar
TexasTrash TexasTrash is offline
1975 Ford F-100
TexasTrash is starting off with a positive reputation.
Neutral Safety Switch
My 75 F-100 starts in all gears, and the reverse lights do not work. Does this mean the NSS is bad.
  #2 (permalink)
Old 06-17-2010, 12:47 PM
tinaheels's Avatar
tinaheels tinaheels is offline
Garage is empty, add now
tinaheels is starting off with a positive reputation.
sounds like something broke on the column,you might want to check if the pin is still there
  #3 (permalink)
Old 06-17-2010, 05:05 PM
jim collins's Avatar
jim collins jim collins is offline
1964 Ford Falcon
jim collins is gaining momentum as a positive member of FTE.jim collins is gaining momentum as a positive member of FTE.
Quote:
Yes, most likely it's bad.
__________________
64 falcon Futura
56 ford Fairlane----
73 f-100 / came with 360 and three on the tree standard trany . Now its 302 with AOD
35 chevy street rod 200 4/R , 350 crate engine.
  #4 (permalink)
Old 06-17-2010, 09:26 PM
TexasTrash's Avatar
1975 Ford F-100
Is the NSS and the backup light switch the same thing on this model truck?
  #5 (permalink)
Old 06-17-2010, 10:11 PM
offroadbronco offroadbronco is offline
offroadbronco is starting off with a positive reputation.
yes, its the same thing.
__________________
96 Bronco XLT, 302/E4OD
77 F-100 Custom, 300/C4, 2WD
  #6 (permalink)
Old 06-18-2010, 12:47 AM
Dirt racer's Avatar
Dirt racer Dirt racer is offline
Dirt racer is starting off with a positive reputation.
Someone must have wired around it for it to start. My 75 has been that way since 92. There is a hole on the upper side of the steering column down by the floor. There is supposed to be a metal tab that moves with the center shaft to change the position of the switch which has a tab that sticks out to hit against it. On mine the metal tab broke. I had to buy a new metal tab and put it in the center shaft. The switch itself was ok. Just never got around to wiring it back up. At least the reverse lights work. I am the only one who drives this truck so not a big deal to me. Hope this helps.
  #7 (permalink)
Old 06-18-2010, 12:53 AM
Kalve's Avatar
Kalve Kalve is offline
1974 Ford F-250
Kalve is starting off with a positive reputation.
calvin mossjr
My 74 does not have a switch or anything like that an it starts with out touching the clutch. The guy helping me told me the neutral safety switch did not come out till the 81 model. Did Ford have them out before the 81 model year an is the 81 model a GM thing? He is use to working on a GM an don't know a lot about Fords. Is there something wrong with mine or is this normal?
  #8 (permalink)
Old 06-18-2010, 02:50 AM
Kynetx Kynetx is offline
Kynetx is starting off with a positive reputation.
That's normal. The neutral safety switch is for automatics. A manual transmission has a clutch interlock instead.
__________________
2004 FX4 5.4: Magnaflow cat-back, K&N intake, Edge CTS Computer, Pioneer AVIC Z120BT GPS
2008 Mazdaspeed-3 2.3 MZR DISI Turbo 6-SP (DD hotrod): Bone stock except for a "Swiss-cheesed" air box
  #9 (permalink)
Old 06-18-2010, 05:12 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
No Ford truck (or passenger car) of this vintage had a clutch interlock switch. It was first introduced in 1984.
C7TZ7A247A .. NSS (Motorcraft SW600) / Obsolete
Fits: 1967/77 F100/350.
DOTZ7BO97B (replaced DOTZ7B097A & C5TZ7B097A) .. NSS Selector Lever ("metal tab" that operates the NSS) / Obsolete
Fits: 1965/77 F100/350.
Both of these parts can still be found at FoMoCo dealers, obsolete parts vendors. The NSS can also be bought from autoparts stores.
Kalve: The guy helping you hasn't a clue. The first FoMoCo vehicle with a NSS: 1950 Lincoln w/Hydra-Matic. Every FoMoCo vehicle with an A/T has had a NSS since.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #10 (permalink)
Old 06-18-2010, 07:12 AM
Kalve's Avatar
1974 Ford F-250
calvin mossjr
ok but this is normal for a truck like this to start up without using the clutch? an the neutral safety switch is for autos only not manual trans correct? An I know he has to look at the Haynes book on this one he has not done a manual trans in 25 years an he is use to GM not Ford he has to call his brother in law bout it who knows something bout these trucks.
  #11 (permalink)
Old 06-18-2010, 08:02 AM
Ford Parts Guru
2013 Ford Escape
Quote:
Didn't you notice what I typed in post #9?
There is no such thing as a clutch interlock switch used on any Ford until 1984!
Prior to 1984, you can start the vehicle with the clutch pedal in or out.
The NSS is only used with an A/T.
__________________
  #12 (permalink)
Old 06-18-2010, 10:55 AM
TexasTrash's Avatar
1975 Ford F-100
Could somebody post a pick of a working NSS. I'm not sure what pin we are talking about, mine has the lever that sticks out and I can move it and the spring is their, but no pin I guess.
__________________
75 F-100, 360, C6, 2WD
  #13 (permalink)
Old 06-18-2010, 11:30 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to all
Here is the illustration from the Ford parts book, the neutral start switch is basic part number 7A247 and the actuator pin is 7B097. The actuator clips to the shift tube and moves a pin that sticks out of the NSS that is attatched to the steering column with two very short screws (42120-S).
Click on the .pdf link to open the file.
  #14 (permalink)
Old 06-20-2010, 02:53 PM
Dirt racer's Avatar
I was looking through Dennis Carpenters parts book last night and they have good pics of both parts. Also sell them. I am sure there are other places that sell them too.
  #15 (permalink)
Old 06-20-2010, 03:44 PM
mikeo0o0o0's Avatar
Quote:
LMC has the parts also but, at least on the actuator pin, Dennis Carpenter is MUCH cheaper (DC P/N D0TZ-7B097-B $12.00, LMC P/N 43-7240 $39.95) On the switch itself there is 5 cents difference.
Tags
1973, 1977, 75, 92, diagram, excursion, f150, f250, ford, location, manual, neutral, nuetral, safety, switch, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
