CDR valve?
Old 06-16-2010, 05:28 PM
wildbill73's Avatar
wildbill73
wildbill73 is offline
CDR valve?
I recently bought my 94 IDI turbo. It just has a hose coming out of the drivers side valve cover. its right where a PCV valve would be on a gas truck. All I can fid is that there should a cdr valve to trap the steamy oil. the ford dealership was clueless so if anyone has any useful knowledge on cdr valves like where to get one. ot would be great. also is it supposed to run back into the intake?
Old 06-16-2010, 06:14 PM
charleswood6969's Avatar
charleswood6969
charleswood6969 is offline
The CDR valve looks like a small can (think tuna fish or cat food) turned on it's side, attached to the intake just below the air cleaner, on the back of the engine. International truck dealerships are about the best place to find one, but you have to provide them either the part number or take your old one in.
Old 06-16-2010, 06:20 PM
charleswood6969
Cut and pasted from a previous thread: (You will need to read, and copy the part numbers)
Do you know when to service your CDR valve?
All 6.9L and 7.3L diesel engines are equipped with a CDR (Crankcase Depression Regulator) valve. Even the new 7.3L Power Stroke is also equipped with the same valve. The CDR valve is one of the leading causes of head gasket failure in these engines. The CDR valve is responsible for controlling the pressure/vacuum in the engine crankcase, and seperating the oil mist from the air and returning the oil to the crankcase. The CDR valve should be serviced every second oil change or when signs listed below are seen.
When the CDR valve is not properly serviced, engine oil enters the air intake and is drawn into the engine. The diesel engine will burn this oil as fuel, however, it is heavier and thicker than diesel fuel and, having greater BTU output, causes excessive heat in the cylinder. Due to the intake manifold design, most of the oil will migrate to #7 and #8 cylinders; the last two cylinders in the rear by the firewall. The increased temperature here will cause the cylinder head to lift off the gasket and allow water or oil to leak out the back of the cylinder head where it meets the block.
To check your CDR valve, remove the air cleaner hold down bolt and inspect it. If the bolt is covered with engine oil mist, it's time to service your CDR valve! Ford calls this item a "Adapter assembly for Crankcase Ventilation" Part number E3TZ-6A665-A or IH part #1805319C1
To service the CDR wash with a solvent, allow to dry, do not use compressed air to dry. There is a small hole in the CDR back cover, ensure it is clean and open. If black chunks of rubber are visible in the intake, on the screen then the rubber membrane has disintegrated, replace the CDR.
Old 06-17-2010, 02:05 AM
lemonshindig's Avatar
lemonshindig
lemonshindig is offline
Type that part number in on this website:
www.partsguyed.com
Best price i found.
-Matt
transmogrifiednow
05-05-2016 10:12 AM
MtTheJeffro
15
10-11-2015 04:56 PM
d-day
09-25-2014 10:44 PM
BeerCan500
08-23-2012 10:09 AM
ghunt
12-23-2007 11:42 AM
Quick Reply: CDR valve?
