1970? F600 VIN Decode - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 06-16-2010, 10:41 AM
awhtx awhtx is offline
awhtx is gaining momentum as a positive member of FTE.awhtx is gaining momentum as a positive member of FTE.
I have located what I think is a 1970 F600 Cab/Chassis. It has an FE series engine in it with a 4 speed transmission and 2 speed rear axle. Can someone decode these numbers?
VIN: F61CKH52419
Model: F61
Body: 4C8
Trans: A
Axle: F3D
164 HP @ 3800 RPM
Old 06-24-2010, 03:59 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
VIN: F61CKH52419
Model: F61 The MODEL code is composed of 4 digits, the 4th is missing.
Body: 4C8
Trans: A
Axle: F3D
164 HP @ 3800 RPM
F61 = F600 2WD (gas).
C = 330 2V Meduim Duty FT engine.
K = Kansas City Assembly Plant.
H52419 = 1970.
F61? = F600. I cannot post what the GVWR is without the 4th digit.
4C8: 4C = Black Heavy Duty all Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
F3D: F3 = Eaton Model 15201 2 Speed Rear Axle / 6.33/8.81-1 / 15,000 lb. Rear Axle Capacity // D = Ford Rockwell Timken-Front Axle / 7,000 lb. Front Axle Capacity.
164 net HP @ 3,800 RPM.
The 1968/72 330 2V Medium Duty FT engine shares a few parts with the 360 2V FE engine, the crankshaft is the same.
FE engines were not installed in anything larger than an F350.
Old 06-24-2010, 11:23 AM
Bill,
Thanks for that information.
I assume that the FE/FT engines are interchangeable so is there any way to tell externally which engine it is? Or do the 330/360/390 all look the same?
Alan
Old 06-24-2010, 12:02 PM
Alan
The engines are not interchangeable. People do swap them around, but it's not a simple bolt in installation.
The 330 2V Medium Duty FT engine shares some parts with FE engines.
The FT 330 2V HEAVY Duty, 361 2V & 391 4V share only a few parts with FE engines.
FE/FT engines look basically the same. The exhaust manifolds are different, as are the carbs, some of which are Holley's with governors mounted on them.
The front/rear engine mounts are different. FT's have one front mount in the center, two mounts at the rear connected to ears on the bellhousing-then to the crossmember.
The only FE engines that mount like this are 1965 F100/250 4WD 352 / 1966 F250 4WD 352 / 1965/67 F350 352. All other FE's have two front mounts, one rear.
Strip all the accessories off, and without a bellhousing, your guess is as good as mine whether the engine is an FE or FT!
Old 01-27-2011, 09:21 PM
mangustrucking mangustrucking is offline
mangustrucking is starting off with a positive reputation.
I just bought a 1970 ford f600 dump truck and was just wondering what all the vin meant F61DKG78308 model F610
F-600 vin number decode mpokoney Large Truck 1 08-03-2015 12:08 PM
vin decoder seohwash Large Truck 2 06-24-2015 05:24 PM
Looking to Decode 1970 F600 Truck coyote1442 Large Truck 1 05-20-2015 05:24 AM
purchasing a F700 vin decode help please canyoncat Large Truck 16 05-31-2014 02:07 PM
1970 f600 vin decode 70F600 Large Truck 1 01-14-2010 01:19 PM
Tags
1970, 1972, 1978, 360, 600, decode, decoder, duty, f100, f600, ford, heavy, number, truck, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
