Carb. leaking fuel
Carb. leaking fuel
I rebuilt the carb. on my '51 Merc. flathead, it is the 94 carb, marked EAB. I put it back on and it runs fine but seems to be leaking fuel from the side of the accelerator pump casting. I can't find the leak, or see a crack, the side of the carb just gets "wet" with fuel once the fuel bowl fills up (running or just cranking). It does not seem to be leaking from the top gasket or the bottom gasket, or from the accelerator pump shaft. It is as if it is leaking right through the casting on the side of the accelerator pump well. It didn't seem to be leaking before I took it off, the only thing I adjusted is the float level, the rebuild kit gave measurements for float level which now seem to be wrong. I am going to recheck the float setting tonight. Could this be the problem? Are there any other things I should look for? Has anyone ever had a casting leak/crack?
karljay
01-11-2005 02:44 PM
drive_old_ride_new
12-03-2004 01:43 PM
bill ballinger
05-30-2001 03:12 AM
