Sat problems with factory nav - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 06-15-2010, 04:37 PM
CarbonClear CarbonClear is offline
CarbonClear is starting off with a positive reputation.
Has anyone encountered any problems with the Sirius sat radio? The problem I'm getting is the unit is showing me channels from 1-100 only. I can't receive channels from 100 and up. Is there a fix for this? Maybe a software update?
Thanks
Old 06-16-2010, 05:37 PM
TIKT B8 TIKT B8 is offline
TIKT B8 is starting off with a positive reputation.
mine is the same.
Old 06-17-2010, 01:18 PM
RoyC RoyC is offline
RoyC is starting off with a positive reputation.
No issue here, I get them all. Has your free 6 mos expired? If so, did you buy all of the channels? There are many options that do not include all of the available channels.
Old 06-17-2010, 05:22 PM
Harley Guy Harley Guy is offline
Harley Guy is starting off with a positive reputation.
Mine works on all... Good gouge on the previous post - what are you subscribed to?
B/R,
Randy
Old 06-24-2010, 11:17 AM
Quote:
B/R,
Randy
Randy, what post was that? I have sirius and xm, basically all the channels.
An update as well, I checked with the dealer to make sure the unit was working properly. Then I called Sirius to see if an update was available or at least find out if they had something to do with it.
If anyone else comes across the same problem, just call Sirius and have them re send the sat signal to the radio and it will update the channel list. You will need to be in the suv to do this though, in order to cycle on and off the radio. Now everything is working fine and I can listen to the world cup......go USA!!!
Tags
2006, 2007, channels, d150, expedition, f350, factory, ford, nav, problems, sat, sirius, truck, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
