1999 f-150 towing - Ford Truck Enthusiasts Forums
1999 f-150 towing
Old 06-14-2010, 06:41 PM
cali201 cali201 is offline
cali201 is starting off with a positive reputation.
1999 f-150 towing
Question. I have a '99 F-150 stepside, 5.4 with 3.55 gears and towing package (at least listed on the window sticker) and my truck only has 88,000 miles on it from new. Auto tranny also. I have been towing my classic car (3100 lbs) on my car trailer (2,000lbs) with no problem. I was thinking of getting an enclosed trailer which is 3200 lbs. Some of my friends say that is too much for my F-150 and I need to step up to somthing bigger. I do live in the mountains in Georgia and have some steep hills to get to my house, but only a short drive, not extended periods of steep hills. Can my F150 tow a total of 6300 lbs ok? The manual says it is good for 8,000 lbs. An enclosed tailer would have more wind drag then my current open car trailer but I will get a v-nosed enclosed trailer if I can do it with my current truck. Thanks for any help.
Old 06-14-2010, 07:41 PM
TheTinian's Avatar
TheTinian TheTinian is offline
TheTinian is gaining momentum as a positive member of FTE.TheTinian is gaining momentum as a positive member of FTE.
I pulled about 12k with mine. About pushed to the limit, but you should have no problems towing 6300k.
Old 06-15-2010, 12:07 AM
jgeese jgeese is offline
jgeese is starting off with a positive reputation.
Have a 2002 F-150 pulling our 26' boat weighing 6300# dry not including the tandem axle trailer. Pull it over the mountains a couple times a year including camping gear. Should be do-able...
Old 06-15-2010, 12:36 AM
cogden's Avatar
cogden cogden is offline
cogden is starting off with a positive reputation.
You will be fine.
Old 06-15-2010, 10:09 AM
ZTG ZTG is offline
ZTG is starting off with a positive reputation.
i have a 99 f-150 4.6l and i haul bobcats with mine . she knows its there but i have never had a problem. 6300lbs should be no problem.
Old 06-15-2010, 11:56 AM
Big Greenie Big Greenie is offline
Temporarily Deactivated
Big Greenie is gaining momentum as a positive member of FTE.
I think it is pushing the limits of the truck. I also think it will do the work, just do it very slowly. With a load leveling hitch, at least D rated tires filled to 65 psi, and trailer brakes in good working condition, it will do it. I bet it would do it for a long time with no problems either. Expect 8-10 mpg though.
I just prefer the turbo diesel trucks for hauling. It is a night and day difference. Lots more power, better suspension and frame, better fuel economy by 5-10 mpg.
Old 06-15-2010, 12:33 PM
Tire ratings have little to do with pulling a trailer vs. hauling a load in your truck. Tongue weight should be about 10% of combined trailer weight when towing.
Old 06-15-2010, 01:44 PM
ZTG ZTG is offline
diesel is totally the way to go but if all you have is your 150 then you have to do what you have to do and she will be fine!!!!!
Old 06-15-2010, 04:43 PM
TheTinian's Avatar
Quote:
x2. After a couple trips towing my old truck around I bought a 7.3 SD.
Car for towing 20 Feet Enclosed Vole Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 31 04-17-2016 03:51 AM
Drama queen on trip... MC5C 1999 to 2016 Super Duty 1 07-13-2014 07:15 PM
1990 F250 351W Manual Tranny & Towing 9000lbs DrunkTruck 1987 - 1996 F150 & Larger F-Series Trucks 13 12-04-2013 09:39 PM
towing an enclosed trailer cali201 1997 - 2003 F150 7 03-29-2011 08:36 AM
Wanting to Tow a 8.5x20ft enclosed car hauler, will my truck do the job?? saleen065 1973 - 1979 F-100 & Larger F-Series Trucks 22 10-12-2009 12:46 PM
Tags
150, 1999, 2003, 3100, 40, 99, f150, ford, lbs, package, rocks, tailer, tow, towing, trailer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
