Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 06-14-2010, 06:41 PM
black water black water is offline
Garage is empty, add now
black water is starting off with a positive reputation.
why wont my propane cheater hose work??
can any one help me out as to why my propane "cheater hose" wont let any fuel into my tank. it was a pain in the ass finding the cheater hose and now my trucks still sitting in spot of my yard that i cant really get anything to pull it out with and its out of fuel and i gotta moce that dirty S.O.B.
any help would be much appreciated thanks!!
  #2 (permalink)
Old 07-04-2010, 04:23 PM
tedtheo tedtheo is offline
tedtheo is starting off with a positive reputation.
You need to turn your 20lb tank upside down so the liquid will flow through. If you have a newer style tank with the saftey shut off it might close off the flow when you turn it upside down. It will be a fairly slow process since it needs a higher pressure in your little tank to force the liquid into your vehicle tank.
  #3 (permalink)
Old 07-05-2010, 05:53 PM
monckywrench monckywrench is offline
monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.
OPDs do hold the valve closed when inverted (which is also why they should be transported in the upright position, so the bottle can vent if overpressure occurs).
A cheater to fit the liquid line off a forklift cylinder would do the job if that is an option.
Tags
20lb, car, cheater, company, flow, fuel, hose, long, make, motor, propane, tank, truck, trucks, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
