Need Help in SW Mich - Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: Toyman
Old 06-14-2010, 05:42 PM
teardropty's Avatar
teardropty teardropty is offline
teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.
I come to this forum with my head hung low. Quick details: I have a 2000 F-350 PSD, 400K miles (maintenance and repairs always done). I have problems with it stumbling/hesitating at 35-45 mph. Above that speed or below it runs fine. When you punch the accelerator down it clears up. I did the Hutch mod, new fuel pump, new fuel filter, new UVCH gasket and wiring harness, 50c mod, New ICP, cleaned fuel bowl, new EBP sensor and cleaned tube, HPOP shows 3/4 level on the oil. It still does the same. I have taken it to 4 so-called diesel mechanics and all claim different problems (more like guesses IMHO). $2000 later the only DTC that comes up is a Turbo Boost Pressure is low. One mechanic tells me I need a new turbo, the other claims fuel injectors, the other 2 recommended I "live with it". When I try towing a 8k trailer it won't do it. There is NO colored smoke out the tailpipe. I decided to bite the bullet and take it to a specialty diesel shop here in SW Michigan. Sadly they are so backed up they can't get to it for 2-3 weeks. This is a work truck and I need it to pull trailers. I am at my wits end. Does anyone know of a GOOD PSD shop around SW Michigan (St. Joseph, Kalamazoo, South Bend, Indiana)? I feel I need someone that truly understands the PSD and their wonderful quirks and not just a general diesel mechanic. Getting someone to do a buzz test seems impossible and now my budget is so low I can't afford a scanner. Or someone from this forum that has more knowledge than I do about the PSD and would be willing to come take a look at it (of course I would compensate). Any help is appreciated. Thank you.
Old 06-14-2010, 10:10 PM
maevans's Avatar
maevans maevans is offline
maevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud of
You need to post this over in the 1999 to 2003 PSD forum.
Great bunch of guys that can answer all you questions.
Old 06-15-2010, 09:04 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Yea, The NBS 7.3 guys are great.
Old 06-15-2010, 09:05 AM
Talyn's Avatar
1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Here is link for you.
Our michigan members dominate the OBS and NBS forums, so its not like your leaving here really. =)
Need someone to install my turbo flainn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 04-29-2013 10:16 AM
Northern Indiana diesel mechanic wanted watatrp Indiana Chapter 1 10-25-2011 06:58 PM
2000 stroke; need opinions about MPG improvements hrsepwr2 1999 - 2003 7.3L Power Stroke Diesel 19 04-19-2011 04:02 PM
Wanted: expert Ford diesel mechanic in SW Austin/Dripping Springs area matthewadams Texas Chapter 3 03-23-2011 09:36 AM
SW Metro Diesel Mechanic Recommendations please... epfire#233 Minnesota Chapter 21 03-09-2011 07:46 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
