Oil & Lubrication
Napa Gold 1734 vs Motorcraft FL1995 Oil Filter
Old 06-14-2010, 01:27 PM
blue1ton's Avatar
blue1ton
blue1ton is offline
Hoping to get some feedback with this question. I have A 2002 Ford F350 with the 7.3 PSD. I use the Motorcraft FL1995 oil filter which I can get for $10-$12 dollars. The Napa Gold #1734 can be purchased online for $13. Is the Napa Gold a better filter? I think the Motorcraft oil filter is a good filter.
Thanks
Old 06-14-2010, 11:38 PM
volksinthevalley's Avatar
volksinthevalley
volksinthevalley is offline
I alwasy go Napa Gold, never had a problem
Old 06-15-2010, 06:20 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Lets think about this some more.
Since we don't know to what specifications Napa has their filters made, nor do we know when they may change vendors or filter constuction to help their bottom line, (after all they are in business to make a profit) & napa doesn't make engines nor test them for hours on end, to decide how their filter should be made.
But Ford does & has to warranty their product, & specifies a filters construction, inside & out, after all of those hours of testing & engine tear down & inspection.
So it seems to me Ford would likely know how to specify the construction of a filter for their engines, or when any changes may be needed to a filters construction later!!!!
Thus it seems to me the benchmark to meet, is still the manufacturers product!!!!
Old 06-15-2010, 01:03 PM
blue1ton's Avatar
blue1ton
blue1ton is offline
pawpaw,
Good point. I think the Napa oil filter is a good quality filter although I never purchased one. On the internet, the Napa 1734 is around $13.00. I called my local Napa and the same filter is $23.00. I have always used the MC #1995 filter which I can get for around $10.00. I think for the money the MC is a decent choice.
Old 06-16-2010, 03:54 AM
Ed's Avatar
Ed
Ed is offline
Great points, all of them in your post, Paw Paw. I agree, although I will say that the WIX / Napa Gold oil filters are well built, and if not using a specified Motorcraft Oil Filter, this WIX / Napa Gold oil filter would be my immediate first choice!
Old 06-16-2010, 09:58 AM
jschira's Avatar
jschira
jschira is offline
That would be great if Ford actually did all those things that you mention.
The reality is that the test data likely came from the filter manufacturer. And the specs likely came from industry standards.
Now Ford may specify a more expense filter media, but that does not mean that no one else uses that same media in its filter.
And you forget, Navistar made (and still makes) the 7.3 and it has its own specs, which are public knowledge.
Ford's specs (if they differ from Navistar's specs) are also well-known to the other filter manufacturers. Long gone are the days that manufacturers can void your warranty for not using OEM parts. Just look at the back of any motor oil for the long list of specs that particular bottle of oil meets, include Ford and Honda's specs for 5w-20. So aftermarket parts manufacturers know full well what the OEM's require. It is no big secret.
So while I agree that all things being equal, going with the OEM is a good choice, paying a great deal more for OEM may not be the best choice.
Old 06-30-2010, 08:02 PM
father/son's Avatar
father/son
father/son is offline
napa wix
fellows, i would like to point out that napa is actually a wix filter,.
wix is one of the best filter companys in the WORLD. they are used everywhere in just about everything that uses oil. million dollar plural heavy equipment have used them for a long long time. those big diesels cost a fortune to replace and the down time is worse money money money. i have no facts, but i would not be surprised if the stock was actually made in a wix plant. no facts just a hunch. you simply can not go wrong with wix. my op and ex. with big cranes. paul
Old 07-01-2010, 05:33 AM
Ed's Avatar
Ed
Ed is offline
Paul, I agree and knew that about Napa / WIX being the same filter, that's why I posted it like that in my first post. Same with the Motorcraft / Purolater Oil Filters.
I have a WIX Filter 2009 Master Catalog, and you are right, they made a ton of various products. It's as thick as a New York Phone Directory!
Ed
Old 07-01-2010, 05:54 AM
jschira's Avatar
jschira
jschira is offline
And Motorcraft filters are made by Purolator.
Champion makes Bosch, STP, Wally filters and a bunch of other private label filters.
Old 07-01-2010, 11:42 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Parts Guy Wyatt is offline
Former Vendor
Old 07-01-2010, 07:55 PM
bucci's Avatar
bucci
bucci is offline
Part Number: 51734
UPC Number: 765809517349
Principal Application: Ford/IHC Trucks w/7.3L Turbo Diesel (94-03)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 8.093
Outer Diameter Top: 4.282
Outer Diameter Bottom: Closed
Thread Size: 1 1/2-16
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=10/30
Burst Pressure-PSI: 385
Max Flow Rate: 28-30 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 3.967 3.587 0.340
Looking at the specs, it seems that the wix filters just as good (95% efficiency at 30 microns) and has a higher burst strength (385 psi).
However, with the info listed, we can't compare construction, flow rate, or capacity. Anything else I missed?
Old 07-04-2010, 11:11 AM
Diesel Man 03's Avatar
Diesel Man 03
Diesel Man 03 is offline
I use the motorcraft filter with no problems, why change a good thing?
Old 07-04-2010, 12:28 PM
jschira's Avatar
jschira
jschira is offline
Availability and/or price.
Old 07-04-2010, 01:43 PM
blue1ton's Avatar
blue1ton
blue1ton is offline
I also stick with the MC #1995 oil filter can't beat it for the money. It's a well constructed filter.
Old 07-04-2010, 02:01 PM
bucci's Avatar
bucci
bucci is offline
Well, how about an update to your original post. Did you learn anything to come up with an answer? What do you think of the Wix/Napa Gold 1734? Is it a suitable/comparable substitute for the MC 1995?
Quick Reply: Napa Gold 1734 vs Motorcraft FL1995 Oil Filter
