Ford F-150 Super Crew Code
Good point, it has 92,000 miles on it and has been trouble free.
Still getting the PO174 code and also "cyl 5 misfire"
Just replaced the coil and plug on what I believe is the #5 cyl. (drivers side front). No change. Is the drivers side front #5?
Yes that's correct, I just arrived in Stockholm so I was just trying to get the truck running until I got back. But I still have a misfire and the analyzer says its a misfire on #5 cyl.
I see where you have replaced the cop and the plug on number 5 cylinder, but have you thought about a bad or fouled fuel injector? You are in Stokholm? Try running some fuel injector cleaner through the system. Let us know the results.
It pays to talk to old guys!
Thanks!!
P0174 - System Too Lean (Bank 2)
Description:
See the description for DTC P0171.
Possible Causes:
See the possible causes for DTC P0171.
Diagnostic Aids:
See the diagnostic aids for DTC P0171.
All — — GO to Pinpoint Test H.
Application Key On Engine Off Key On Engine Running Continuous Memory
P0171 - System Too Lean (Bank 1)
Description:
The adaptive fuel strategy continuously monitors the fuel delivery hardware. The test fails
when the adaptive fuel tables reach a rich calibrated limit. Refer to Section 1,
Powertrain
Control Software
Fuel Trim for more information.
Possible Causes:
Fuel System:
Ethanol content in the fuel
Fuel filter plugged or dirty
Damaged or worn fuel pump
Leaking fuel pump check valve
Leaking or contaminated fuel injectors
Low fuel pressure or running out of fuel
Evaporative emission (EVAP) canister purge valve is leaking when the canister is clean
Fuel supply line restricted
Fuel rail pressure (FRP) sensor bias
Exhaust System:
Exhaust leaks in the exhaust manifold gasket or mating gaskets before or near the heated
oxygen sensor (HO2S)
EGR System:
EGR System:
Vacuum hose disconnected on exhaust gas recirculation (EGR) system module (ESM)
applications
EGR valve tube or gasket leak
EGR vacuum regulator solenoid leak
Intake Air System:
Air leaks after the mass air flow (MAF) sensor
Vacuum leaks
Positive crankcase ventilation (PCV) system is leaking or the valve is stuck open
Incorrectly seated engine oil dipstick
Intake air turbulence due to incorrect air filter
Damaged or contaminated MAF sensor
Diagnostic Aids:
View the freeze frame data to determine the operating conditions when the DTC was set.
Observe the LONGFT1 and LONGFT2 PIDs. Refer to Section 2,
Adaptive Fuel Diagnostic
Trouble Code (DTC) Diagnostic Techniques
, for more information and the appropriate
HTH- Tim
This is for 09-10 guessing the DTC's might still be the same?
pinpoint test for specific concern identification.
HTH- Tim
96fordtruck
07-28-2008 08:06 AM
rocky3539
04-20-2007 03:52 PM
