2 inch front leveling kit - before and after - Page 8 - Ford Truck Enthusiasts Forums
  #106
Old 06-17-2011, 09:08 AM
Sgt93 Sgt93 is offline
Sgt93 has a brilliant futureSgt93 has a brilliant futureSgt93 has a brilliant futureSgt93 has a brilliant futureSgt93 has a brilliant futureSgt93 has a brilliant futureSgt93 has a brilliant futureSgt93 has a brilliant futureSgt93 has a brilliant futureSgt93 has a brilliant futureSgt93 has a brilliant future
Alright, after reading the whole thread through, Maybe the ICON 2.5" lift kit instead. Back to my original thought.
  #107
Old 06-17-2011, 11:21 AM
720Deere's Avatar
720Deere 720Deere is offline
720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future
Quote:
If you like the ICON kit, you may want to check out RCD (Race Car Dynamics) Ford F250 4wd
Their leveling kit is by all indications the exact same thing as ICON at 2/3 the cost! Having used just spacers on my 2006 F350 and lived with that for 4 years, I would much prefer to spend the extra money this time for the full spring kit along with some Billsteins to rid me of these worthless Rancho shocks.
  #108
Old 06-17-2011, 11:50 AM
Thanks for the link bro!
  #109
Old 06-17-2011, 01:29 PM
The kit says it fits 05-10 models. Will it fit the 2011? I just emailed them as well. Price is good. Thanks again. -Steve
  #110
Old 06-17-2011, 03:06 PM
Yep it fits. Speedy response!
Hello Steven,
Yes, it fits all 2005-2011 models. If you have any questions or need anything else please let us know.
Thank you for the inquiry.
Matt
RCD Suspension
  #111
Old 06-18-2011, 01:35 AM
lakedweller's Avatar
lakedweller lakedweller is offline
lakedweller is starting off with a positive reputation.
Quote:
Originally Posted by EpicCowlick View Post
Yes, the fifth wheel puts 3,700 lbs in the back. Compresses the rear 3 inches. One button on the airbag compressor and it comes back up 2 inches. Exactly level front to back.
When I put my 5er, 2400 lb pin weight, on my truck it sets level and I do not want to put air bags on this truck. I have to be getting better fuel mileage with my truck going down hill empty....
  #112
Old 06-23-2011, 03:22 PM
bill buxton bill buxton is offline
bill buxton is starting off with a positive reputation.
Talking ROUGH COUNTRY
I did mine with the rough country leveling kit and its the way it should be now. Level with no front end sag or rake whatsoever. The ride was not changed by the kit install and it looks nice...
  #113
Old 09-15-2011, 01:40 PM
aquasport17 aquasport17 is offline
aquasport17 is starting off with a positive reputation.
Update?
Curious to know after several months now, how you guys are making out with the 2" lift. Any tire wear issues, handling or loading issues? Did anyone decide to install the adjustable track bar to bring the axle back in line?
I have a 2011 F350 that has the considerable amount of lift in the back as stated in this thread. My 09 F250 sat nice and level and was CERTAINLY higher off the ground in the front compared to the 350. Maybe the rake causes it to lose clearance up front I don't know.
After reading MANY threads on this subject, I'm contemplating the Autospring kit used here, and possibly a track bar.
Did you guys swap out your stock shocks? I don't really care for the extensions.
Ready-lift appears to make a pretty comprehensive package and I am considering that as well.
Any other advice?
I'll likely follow with dumping the stock michelins as well.
Cheers,
Jeff
  #114
Old 09-15-2011, 08:10 PM
720Deere's Avatar
Personally I think the whole track bar issue is way over-blown. Looking at a leveled truck 9 out of 10 people can't tell the difference in the axle location. An adjustable bar is a huge investment just to satisfy your own mind that everything is where it belongs.
Having driven several leveled trucks with both the coil spring suspension and the older leaf spring suspension I have never noticed any handling issues caused by the 3/8" to 1/2" that the axle moves with a leveling kit.
Just about any of the leveling kits out there will work just fine. It all comes down to personal preference. I would be looking for one that comes with caster angle adjustment shims. Adjusting the caster is the most important thing. The shock extensions are a non-issue, but replacement shocks are a much more desirable option since the factory shocks are pitiful at best.
  #115
Old 09-16-2011, 11:55 AM
TexasA&M's Avatar
TexasA&M TexasA&M is offline
TexasA&M is gaining momentum as a positive member of FTE.TexasA&M is gaining momentum as a positive member of FTE.
Which one comes with caster shims? Couldn't this just be taken care of at an alignment shop after the install is done?
  #116
Old 09-16-2011, 01:53 PM
11350KINGRANCH's Avatar
11350KINGRANCH 11350KINGRANCH is offline
11350KINGRANCH is starting off with a positive reputation.
I have had no issues with mine. It has been from NJ to Houston and back, all over the east coast, and I'm down in WV with it now.
  #117
Old 10-13-2011, 05:51 PM
graphics1988 graphics1988 is offline
graphics1988 is starting off with a positive reputation.
..i just had the readylift stage 3 installed in my 2011 F250 CC, and it looks great, but for some reason i thot it was a levelling kit...and it seems like the front sits a fair bit higher than the back...and it has a wishy washy feel to it, when i get on the throttle during passing.....i am gettin a bit concerned...stock Michelins with 20" rims still too...the mechanic said there were a couple extra parts in the kit and has no idea where they go...this is a good mechanic too...he said there was nuthin in the instruction manual on them either....i wish i knew how to upload a pic on here! lol.....
  #118
Old 10-13-2011, 06:09 PM
EpicCowlick's Avatar
EpicCowlick EpicCowlick is offline
EpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud ofEpicCowlick has much to be proud of
Quote:
Sounds exactly like the caster needs to be adjusted. Extra parts? Hmmmm... I'd be on the phone with Ready Lift right away.
  #119
Old 10-13-2011, 07:16 PM
Hdslider's Avatar
Hdslider Hdslider is offline
Hdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputation
Ditto X 2 on Epics reply.
  #120
Old 10-13-2011, 08:05 PM
machine62's Avatar
machine62 machine62 is offline
machine62 is starting off with a positive reputation.
If I recall correctly I had two brackets left over and think they had something to do with the inner fenders. Not 100% sure what they were for but I never installed them and haven't had any problems.
1949 ford laying running boards down2earth 1948 - 1956 F1, F100 & Larger F-Series Trucks 36 09-06-2015 02:35 PM
12V Keyed Accessory Wire? EpicCowlick 6.7L Power Stroke Diesel 5 05-01-2015 02:52 PM
e99 35 inch Wrangler Duratracs No Lift (Picture Heavy) Lloydable 1999 to 2016 Super Duty 12 02-17-2012 02:23 PM
SEMA 2011 EpicCowlick 6.7L Power Stroke Diesel 25 11-05-2011 02:23 PM
The progress of Big Green (pics) Tha_Stepside 1973 - 1979 F-100 & Larger F-Series Trucks 25 08-24-2008 08:28 PM
Tags
04, 2, 2011, escape, f150, f250, ford, front, inch, kit, kits, leveling, purpose, ranger, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
