2 inch front leveling kit - before and after - Page 11 - Ford Truck Enthusiasts Forums
  #151
Old 10-23-2013, 12:11 PM
ScottyDog's Avatar
ScottyDog ScottyDog is offline
ScottyDog has much to be proud ofScottyDog has much to be proud ofScottyDog has much to be proud ofScottyDog has much to be proud ofScottyDog has much to be proud ofScottyDog has much to be proud ofScottyDog has much to be proud ofScottyDog has much to be proud ofScottyDog has much to be proud of
Quote:
Originally Posted by 98woody View Post
Everyone mentions 4" blocks am I missing something? The stock f350 block is 3 1/2" the next step I found is the ready lift 5". If there truly is a 4" block im interested since im installing a 1 1/2" front bottom spring spacer on an f350. The 5" is too high.
Top Gun Customz - Lift Block Sets
  #152
Old 10-23-2013, 03:45 PM
98woody 98woody is offline
98woody is starting off with a positive reputation.
I ended up with 1 1/2" spacers up front and stock f350 blocks in the rear I have 3/4" of rake
  #153
Old 10-26-2014, 09:29 AM
mtnxtreme800 mtnxtreme800 is offline
mtnxtreme800 is starting off with a positive reputation.
Just bought a 12 F 250, so I'm going 35/12.50-20 just to confirm, 2" level kit in front and remove F 250 blocks and replace with F350 blocks in rear, is it cheaper to get the blocks for rear aftermarket, and if so how thick are they, I can just imagine the price of F350 blocks from Ford ! I also notice Top Gun has the 2" leveling for $69 as opposed to Auto Springs $128 but Top Gunz don't include the shock extensions, are they a definite must ?
  #154
Old 02-07-2015, 09:10 AM
SAMs 250 SAMs 250 is offline
SAMs 250 is starting off with a positive reputation.
2015 Rough Country leveling kit
Looking for some feedback/advice, I purchased the Rough Country 2 inch leveling kit item 514. Haven't installed it yet....looking for some feedback before installing it on my 2015 Super duty.
Thanks
  #155
Old 02-07-2015, 03:00 PM
SultanGris's Avatar
SultanGris SultanGris is offline
SultanGris is starting off with a positive reputation.
Quote:
Thanks
You pull anything? If you do you're headlights are gonna point at the sky after a level kit. Personally I would never use one, every truck I see with one has a sagging rear if hauling or towing even something light and then they look dumb as hell, lol!
F150s can sometimes get away with it, they have stiffer suspension. My 350 squats as much or more pulling the same 5th wheel as my 150 did, 350s have a little softer top springs for a better empty ride, which is 1000 times smoother than a Chevy hd.
  #156
Old 02-07-2015, 05:07 PM
Sterling6.7 Sterling6.7 is offline
Sterling6.7 is gaining momentum as a positive member of FTE.Sterling6.7 is gaining momentum as a positive member of FTE.
Thanks
A leveling block is nothing more than just that, no matter the brand. The more expensive kits come with brake line relocation brackets. Probably wouldn't hurt to re-adjust your headlights after. Regarding the towing squat, you are going to get that regardless of the presence of the leveling kit. Completely a different issue and you will need air bags or similar to fix that.
  #157
Old 02-08-2015, 05:01 PM
msgtord's Avatar
msgtord msgtord is offline
msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.
My truck has always looked level to me. After reading this thread I decided to put the tape measure on mine. With a tool box with a bunch of tools and a floor jack, mine is at 41 inches front and fear. I guess the "camper package" and heavier duty springs raise the front ride height.
  #158
Old 02-27-2015, 10:14 AM
93-331-29PSI 93-331-29PSI is offline
93-331-29PSI has a good reputation on FTE.93-331-29PSI has a good reputation on FTE.
I have the snow plow prep package on mine and while it's not sitting on solid pavement I decided to tape my truck anyhow and my Measurements with stock tires (LT275/65/18) are roughly as follows:
Front 40.5"
Rear 42.5"
Now if I add the difference (1.5") in tire size for the 35x12.5 tires to my original measurements I'll be at:
Front 42"
Rear 44"
Now I am looking at and considering the Ready Lift 1.5" kit (installs on bottom of spring) which I think will put me where I want to be
Front 43.5"
Rear 44"
Does anyone think I'll need a track bar relocation kit with only the 1.5" kit?
1949 ford laying running boards down2earth 1948 - 1956 F1, F100 & Larger F-Series Trucks 36 09-06-2015 02:35 PM
12V Keyed Accessory Wire? EpicCowlick 6.7L Power Stroke Diesel 5 05-01-2015 02:52 PM
e99 35 inch Wrangler Duratracs No Lift (Picture Heavy) Lloydable 1999 to 2016 Super Duty 12 02-17-2012 02:23 PM
SEMA 2011 EpicCowlick 6.7L Power Stroke Diesel 25 11-05-2011 02:23 PM
The progress of Big Green (pics) Tha_Stepside 1973 - 1979 F-100 & Larger F-Series Trucks 25 08-24-2008 08:28 PM
Tags
04, 2, 2011, escape, f150, f250, ford, front, inch, kit, kits, leveling, purpose, ranger, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
