04 f250 gear selector release switch - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-13-2010, 05:15 PM
swinehart07 swinehart07 is offline
swinehart07 is starting off with a positive reputation.
Well the switch that is mounted to the brake pedal that allows you to shift out of park only while applying the brake has begun to annoy me. Currently I have to reach up under the dash and lift up on the sensor housing to get it to release the lock. At first it would only happen once in a while but now it is everytime. I am going to pull it out and spray it good with some electronics cleaner soon, but I was just curious how many other people have had this problem with their trucks.
Old 06-14-2010, 11:34 AM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
It happens often. Mine was actually blowing the fuse that controls that switch. It ended up being the cruise contol. Another problem some have run into are some of the bolts that hold the steering shaft down are coming loose and create similar issues. You have to take the column covers off to see those bolts tho, and when or if you check them it is also a good time to check the wire that come from the shifter od button. They are know to short out where they come out of the shifter.
Old 06-15-2010, 08:22 PM
Hey thanks for the input. I will have to give it all a good look over.
'01 Escape Stuck in Park; safety interlock gary7388 Escape & Escape Hybrid 35 12-22-2014 05:19 AM
Lever stuck in park and no brake lights? update ! So-Cal Sancho 1987 - 1996 F150 & Larger F-Series Trucks 3 07-26-2012 01:52 PM
99 f250 brake problems dozerdug 1999 to 2016 Super Duty 1 07-23-2011 07:59 AM
Parking Brake Light redman84 1994.5 - 1997 7.3L Power Stroke Diesel 4 10-14-2010 10:44 PM
Emergency Brake Light Stays On Raintree55 1967 - 1972 F-100 & Larger F-Series Trucks 10 03-08-2003 04:49 PM
Tags
2002, 2003, 2004, brake, button, diesel, excursion, f150, f250, ford, gear, release, selector, shift, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
