223 6 cyl Temp Sending Unit
No, but here is the one from C&G Ford Parts if you want to try and cross reference it or buy direct from them:
https://secure435.hostgator.com/~dlv...=107&t=785&tn=
They are $55.
NAPA has no listing for it.
They are $55.
The unit will come with a MIP type nut fitting, which will be tapered. Also, it's soft brass so the threads will conform and compress to the engine threads as you tighten it. Be sure not to overtighten and strip it. About 20 ft/lb is enough. If it leaks after that, give it another 1/8 turn.
Hit the threads with a shot of "3 in 1 Oil" or WD-40 first just to help lubricate the threads during installation.
Well I replaced the sending unit, fired her up and the gauge works great! But now (reasons unknown at the momment), after idling for 2 or 3 minutes, the engine dies and it tough to get started. I tried this a few times but get the same result. The darndest thing is that it was running beautifully until I changed the sending unit. Strange. I pulled 1 plug to see what was going on and it was pretty fouled. A new set of plugs will go in tomorrow and hopefully this will cure the problem. Any other ideas what could be causing this?
OnlyAGeologist
07-18-2012 09:56 AM
sleddog60
04-17-2009 05:43 PM
oscarxyz
04-28-2008 02:49 PM
7pointstar
05-10-2007 01:02 PM
Denver351W
09-25-2006 11:03 PM
