Need help troubleshooting power window switches
First is there a thread or tech article somewhere that would help? The passenger side window does not work with either switch. I remove the plug on the passenger side window switch and apply 12V and ground to the 2 wires going to the window motor and the window works one way. I reverse the jumper wires to the pigtail and it works the other way (up/down). So I think I have isolated it to be a switch. Now, how can I test to see which one it is?
both windows ground through the driver door switch. If the driver side window works, and the passenger side doesn't, then the problem is either in the wiring between the passenger door and the driver switch, or the driver switch itself.
I would substitute a known good switch on the driver's side. If that doesn't work, you need to check cointinuity of the wiring between the two sides.
Randy Page
Electrical Systems/Wiring
02-21-2006 11:13 PM
