wipers won't turn off? - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 06-12-2010, 08:50 PM
JKK JKK is offline
JKK is starting off with a positive reputation.
Hi all,
Did some searching but couldn't find a close answer. My wipers won't turn off...even in off position the run as if they were at the lowest intermittent speed. I worked the swich back & forth a number of times to make sure it wasn't sticking & no luck.
Any ideas or do I have to replace the entire wiper stalk assembly (assuming its the switch which is faulty & I know the entire assembly is all or nothing on replacement)?
Thanks in advance...I think I gotta replace the whole thing BUT just in case someone has an idea on a quick fix figured I'd post it here.
Thanks!
Old 06-13-2010, 07:30 PM
JKK JKK is offline
okay, just ordered a new turn signal stalk/wiper control assembly on EBAY...dang cheapo switches cost way too much to replace..ha
if anyone has an 00' Excursion front license plate bracket they want to unload please message me...thanks!
Old 06-13-2010, 09:26 PM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
I bought my license plate holder off Ebay for $13 last year. It was also OEM Ford.
Old 06-19-2010, 11:00 PM
JKK JKK is offline
Hi all,
STILL having issues w/ wipers. I figured since they would not go off in the off position switch was bad. Ordered a new switch/turn signal assembly. Put in in today, popped fuse back in & now they don't go off at all, in high speed position, & the rear wiper won't go off either??? I figured it would just have been a bad switch but now is weirder than ever!
Anyone have any ideas?? I have no clue how to to trouble shoot this one??
Help! Thanks!
JK
Old 06-19-2010, 11:14 PM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
my uneducated guess, it's a short.... (but u knew that )
How about pulling one fuse at a time to see what effects it...
Sorry, sounds like a tough one... god luck !
Old 06-20-2010, 01:39 AM
tonyv74 tonyv74 is offline
tonyv74 is starting off with a positive reputation.
I got a cheap turn signal lever from ebay as well and it was the same problem. The wipers wouldn't turn off after using the windshield washer fluid or just turning it on. The only way was to shut off the engine. I just sucked it up and got an OEM one at the dealer which was almost double the cost.
Old 06-21-2010, 02:08 AM
jh818's Avatar
When I replaced my multi-function switch (turn signal switch) for the 2002 Ex., it was different from the 00-01. At the time, someone on ebay from Sugarland, TX was selling the OEM for 00-01, so I couldn't use it. Bought an 02 switch from an online Ford dealership parts dept. in Ontario, OR (Gentry Ford) for $65 or something like that. My old one had the problem of the right signal not returning back after you make the turn.
What the hell is going on with my wipers... RIKIL 1987 - 1996 F150 & Larger F-Series Trucks 3 10-04-2015 12:44 PM
wipers won't turn off except with key sammiestoyz Ranger & B-Series 2 11-26-2011 09:19 PM
wipers won't turn off except with key. 1996 ranger sammiestoyz Ranger & B-Series 2 11-26-2011 03:28 PM
1999 F-150 Wiper problems skip17 1997 - 2003 F150 4 04-06-2011 10:45 PM
wipers won't turn off???? JKK Electrical Systems/Wiring 4 06-21-2010 11:01 PM
Tags
2001, 2005, 2006, 92, escape, f250, ford, jaguar, rear, shut, stalk, taurus, turn, wiper, wipers, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
