Inline fuel filter 1995 E-350 5.8L engine
Hey guys,
I have an inline fuel filter I am trying to replace. There are steel spring clips on either side of the filter. They clamp over the crimped end of the fuel line on one end, and then over the steel nipple of the fuel filter. I have removed the spring clips, but cannot seem to get the crimped on portion of the fuel lines (in and out) to come off. Do I need a special tool, or what am I missing here? Please help and advise! Thank you!!!!!
To use the tool, push the line you wish to disconnect from the filter into the filter fitting as hard as you can and hold it there, then push the tool in to hold the fingers "out", then pull the line clear of the fitting.
Again it is important you do not pull on the line until you are sure you have the tool fully inserted into the fitting, you'll know when you do, or you'll just make it worse.
FordIowan
16
03-01-2021 05:19 PM
Poppa Squirrel
11-17-2015 08:46 PM
theotherBeachboy
09-03-2015 08:17 AM
leebrown5
07-13-2011 04:03 PM
ebraunusa
1997-2006 Expedition & Navigator
18
12-14-2010 11:20 AM
