2002 Expy XLS 4X4 - suddenly no electrical
Hi all,
I had a weird problem last week and after countless google searches, I have come up short of any answers.
Details: 2002 Ford Expedition with the 5.4L 260 hp V8 and 89K miles
Issue: The wife called after a quick run to the hardware store indicating the truck would not start. She indicated there was a ticking sound coming from inside the vehicle and that turning the key made no noise or anything.
When I got to the ticking noise was still occurring and it was coming from the fuse panel. I removed the panel and it felt as though it was coming from relay1. In this condition, no lights would work or any electronics in the vehicle other than a few dash lights. The ticking continued for another 10 min then suddenly stopped. After it stopped, the truck start and everything was normal.
Once home I pulled the battery and had it run through a test. Everything checked out fine.
One last weird thing.... about eight months ago I brought it in for service because the rear drivers side door would not function. They indicated a window motor problem and the repair was ~$500. I decided against the repair due to cost. For some reason now the window appears to work again. The rear wiper which also stopped working now seems to function.
I am worried about electrical issues but am far from being able to determine the root cause myself.
Thoughts on what this may be?
- Could the window issue actually be a short which caused the complete electrical failure?
- Could it be an aging or faulty car alarm?
Thanks for any advice or help!
I'd say the issue of the vehicle not starting was probably dirty battery posts and cables. When you pulled, then reinstalled the battery, you probably got a good electrical contact between the two again. The windows intermittently operating sounds to me like you may have corroded contacts where the harness connects to the motors. I'd pull the harness, clean the the contacts up the best you can, apply some dielectric grease on them then hook them back up.
Any recommendations on how to determine if it is the GEM while it is in working condition?
Between this and the well kown blown plug issue (#3 went on me a month ago) I am starting to wonder if I should sell and pick up something else. Problem is it is in great shape otherwise and fully paid which is real nice.
Solved
It turned out to be the actual battery cables/connectors. The original cables were cut and new terminals were put on about two years ago. Apparently the voltage drop was just enough to cause these problems. They replaced the cables/terminals and it seems to have solved the problem. Thx all for your help!
joshjosh123
10-08-2015 10:19 PM
huittdvm
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
05-13-2015 06:45 PM
venom_99
05-30-2004 05:46 AM
