Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 06-12-2010, 05:52 AM
Midwest Dually's Avatar
Midwest Dually Midwest Dually is offline
1994 Ford F-350
My Garage
Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.
WVO titration testing...
Lets see who can help me with this! LOL!
OK, so I am in the process of completing Titration testing. Here is a couple problems I am having, and maybe I am just not catching it. I caught some tables to do the testing, but it is for much smaller amounts (400ML) and what I need to know, is how do I increase my measurements for larger quantities for processing. Any tables out there for conversion that someone uses?
Second, everything I am finding for my titration testing, is using KoOH and not NoOH. If I am using NoOH for my processing, mow much difference between the math for it as compared to the KoOH amounts?
Any input and help would be wonderful!
__________________
- Chris -
1994 F-350 CC Dually : DRW 4x4 XLT, 97 7.3 DIT conversion, tuned, open pipe and modded!.
  #2 (permalink)
Old 06-12-2010, 06:54 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
If you're using NaOH, disolve 1 gram of NaOH in 1 liter of distilled water for your titration solution, and you won't have to do any conversion... Most of us use KOH though since it is easier to work with, and the Glycerine is not as thick...
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #3 (permalink)
Old 06-12-2010, 09:25 PM
eknispel eknispel is offline
Garage is empty, add now
eknispel is starting off with a positive reputation.
When performing a titration, (either with KOH or NaOH), a small sample size is the intention (I titrate only 1 mL of waste oil). But the important number is the volume of catalyst(KOH or NaOH) that is used to neutralize your sample. That number is your "BASE" number and is then modified according to the type of catalyst.
For example: If I use 4 ml of my titration solution to neutralize my oil, my BASE number is 4. Because I am using NaOH, I add 5.5 to the 4 = 9.5
That 9.5 has the units of grams NaOH per liter of WVO (grams/Liter). If you have 100 liters of WVO then 100 x 9.5 = 950 grams of NaOH that must be added to your methanol.
Good luck.
  #4 (permalink)
Old 06-12-2010, 09:39 PM
1994 Ford F-350
My Garage
Wow... Awesome! Thank you both!
__________________
- Chris -
Tags
distilled, process, testing, tirate, titration, water, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
