I need help again 350 cui or 455 cui from Odlsmobile - Fritz from Germany
aus hier: Olds FAQ -- Engines
"Some blocks, before 1977, have thier ID cast above the right hand center freeze plug, eg. D for 425, F for 455. Olds didn't cast the displacement into the side of the blocks until they went to the light weight design in 1977. The 1977 and newer blocks will have the cubic inches cast in large raised numbers right above the right hand center freeze plug, eg. 403. The 307 will be in liters (5L), and a diesel engine will have the letters "DX" on it. The engine VIN letter will also be cast into the side of the block. Note that the 260 blocks sometimed have the last 3 digits of the casting number cast there, "355", which is rather misleading. "
This doesn't look like the righthand center freeze plug, but I don't know what else it could mean.
Oh meine Güte, Fritz, mein Deutsche ist SCHRECKLICH!
Ich kann nicht es Al alle verstehen. Ich bin solch ein Idiot! Aber mindestens weiß ich, wie man das On-Line-Wörterbuch gebraucht!
Hoffentlich sagte ich " Ihre Mutter nicht treibt einen Chevrolet. "
Ich hoffe, dass jemand auf Ihre Frage antworten kann
Begrüßen Sie Ford-Lastwagen-Enthusiasten
From: OLDSmobility.com - The 1967 Oldsmobile Cutlass and 442 Resource -
"The external dimensions and bolt holes on all 330/307/350/403/400/425/455 Olds engines are the same. If you're using a Toronado 455, you'll have to find brackets from a RWD car. All of the RWD V8 brackets are designed to fit both big and small blocks;"
As long as the crossmember you buy is for an Olds, and you use the stock Olds mounts/brackets, you should be good to go.
es hilft ,wenn Sie es inEnglisch ,da einige von uns Kann Deutsch , oder ein wenig daruber reden , aber wie wir / i Jahren den Geist schwach , und es macht mir Kopfschmerzen , es zu benutzen , den Geist.............................. Wilkommen im Forum !!!!!!!!!!!!!!! good lord i hope that's right and i didn't just proposition someone or worse LOL !!!!!!!!!!!!!!!!!!!!!!!!!!!!
