Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-10-2010, 10:58 PM
77f250400 77f250400 is offline
Garage is empty, add now
77f250400 is starting off with a positive reputation.
need help with propane
hey every one im new here i have a 76 f250 4x4 with 400 on propane the problem im having is that i i can not get the propane from the bbq tank threw the cheater hose it wont go in the filler on the truck the truck is not out of propane dose that matter and my bbq tank is half full dose that mater or any other point im forgeting or places i should be looking to fix or replace i will take any other opinons
  #2 (permalink)
Old 06-11-2010, 11:09 AM
gasman6674's Avatar
gasman6674 gasman6674 is offline
1996 Ford F-350
gasman6674 is starting off with a positive reputation.
Your BBQ tank is vapor out to transfer the gas from it to your motorfuel tank you would have to turn it upside down HOWEVER new 20# cylinders have an OPD Valve (overfill protection device) that WILL NOT allow that to happen. Take it to a dealer and get it filled.
__________________
Jim England
Do you have Gas? Propane Execeptional Energy
2012 Escape Ltd FWD, 2005 Explorer Sport Trac 2WD
2004 Escape Ltd FWD, 1996 F350 7.3L CCLB DRW,3" DP,4" Exhaust, Cat Delete, 6637
2012 V-Cross V27FK Super Lite by Forest River TT
  #3 (permalink)
Old 06-11-2010, 11:12 AM
Elderstarr's Avatar
Elderstarr Elderstarr is offline
Elderstarr is gaining momentum as a positive member of FTE.
I've only ever had to use a cheater line twice, and both times I turned the bbq bottle upside down and above the main tank to fill it. Otherwise you're just balancing the pressures in the tanks and will never empty your bbq cylinder.
Edit... Didn't know about the OPD valve on the new cylinders. Been a while since I've needed to cheater fill. I'll keep my oldest bbq tank full for emergencies. To the OP, get a reliable gauge on your tank and never worry about filling your truck on the side of the road.
__________________
1987 F-250 Ext/Cab: LPG 351W, 6" Lift, D44 SAS, ZF5
In paint & bumper reconstruction. Wait for upcoming Vulgarity
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
