My overdrive light is blinking???
Old 07-17-2015, 12:35 PM
B Big's Avatar
B Big
B Big is offline
Originally Posted by B Big
The overdrive light blinking & the hard shifts relate to a sensor that is on top of the rear end. This sensor is alot like the CPS. I've got a price quote from the local NAPA store for $15.00 for one & they even had it in stock.
I haven't replaced mine yet, but I need to. When my truck starts shifting hard I just pull over & stop & shut the truck off & then restart & the problem stops for the time being.
Update: I did replace the sensor on the diff, but that didn't solve the problem.
On my truck the blinking was b/c the torque converter in the trans had failed. The T/C stopped locking up. I ended up having the trans rebuilt/replaced.
Old 07-29-2015, 08:25 AM
keith20mm's Avatar
keith20mm
keith20mm is offline
As a side note on reading transmission codes, the little Chinese ELM-327 code reader does have a way to read the extended codes, of which the transmission codes are some of.
These readers come as both Bluetooth, USB, and RS232 connection types. The Bluetooth works with tablets/phones and Bluetooth laptops. The USB works with laptops and PCS with USB, and the RS232 works with generally older PCs and laptops having RS232 connector.
Any of these are available for typically less than $10, and include software app or a place to download the app.
Further, they are simple to use, and will get you your extended OBD transmission codes.
Old 07-29-2015, 02:44 PM
BBslider001's Avatar
BBslider001
BBslider001 is offline
Not for the OBS 7.3 Diesel...try again
Old 07-23-2019, 11:00 PM
Samir Delic's Avatar
Samir Delic
Samir Delic is offline
Overdrive blinking
I have a same problem overdrive was blinking shifting hard when I replace the tachometer sensor overdrive light is gone and shifting smoothly
Old 07-24-2019, 12:22 PM
friskyjake's Avatar
friskyjake
friskyjake is offline
Where is the Tach sensor ?
Old 05-24-2022, 11:07 PM
S P's Avatar
S P
S P is offline
2nd Gear
Abs sensor?
He probably means the abs sensor. It's a short term fix but will fail again.
Old 07-29-2022, 02:36 AM
Marco 1989's Avatar
Marco 1989
Marco 1989 is offline
4wd Low
Do you have a picture of this sensor or were its located by any chance.Thank you.
Vijay
1999 to 2016 Super Duty
23
06-14-2013 12:14 PM
zed326
1997-2006 Expedition & Navigator
01-13-2009 08:19 AM
Orlie
03-09-2005 08:32 AM
gotama
11-15-2004 09:29 PM
ejmatthews
03-10-2004 01:27 PM
Quick Reply: My overdrive light is blinking???
